Head Studs vs. Head bolts
I have head bolts now on my H/C/I lt1. I will be putting my new 383 in my car in a few weeks and need to know if i need head studs? i will be using stock cast LE heads and be running about 15lbs of boost.
does anyone know the P/N on LT1 studs?
Oh studs allow a more precise torque measurement for the head, and also stretch less.
its ok im going to buy the head studs.
the guy at Jegs said the SBC head studs are the ones i need. any comments.
SB-Chevy, OEM Cast Iron and Aluminum Chevrolet
Part Number: 070-134-4001
first off its easier for a race engine builder to build a motor with studs than bolts.....its just pain out faster to assemble........but more importantly, when you torque a bolt down its encountering two forces a rotational stress from torquing the bolt tight and a vertical axis sretch from the bolt being pulled apart......the roatational stress can skew the proper torque reading.....when we use a stud....the bolt is encountering only a vertical axis stress there fore alowing the bolt to be torqed down more properly and therefore prevents any lifting and shifting of the cyl head better than a bolt........
huh????
