Head Studs vs. Head bolts
i wouldn't install them with the heads already in place. You will get sealant all over/in between the head gasket layers, block, head etc. I use plenty of copper silicone to seal mine, I do them on a short block, use brake cleaner and a ton of paper towels to clean every bit of excess. Then need to get the studs torqued (3 steps) while the silicone still hasn't set up. I've never had a stud leak, and neither has my builder who uses the same method. Time consuming, yes. But better than having to do it twice and wasting a head gasket.
