Is it safe to hot tank my intake and timing cover?
The new stuff is pretty good if you haven't tried it: Fume free and even has a decent smell like lemon. There is no reason you couldn't use it INSIDE if you wanted to. The older style oven cleaners may be a little much to deal with, but then again, most ovens are probably indoors anyway. Doesn't leave you much choice.
Just another option - This works pretty good:
![](http://i52.tinypic.com/2lj4ww0.jpg)
Easy-Off oven cleaner... Spray it on, and let it set for a while. Use a brush to work it into the gunky areas. It will take few applications, hosed down, or power-washed in between, and that's how mine looked when I was done. You can see it's just as clean on the inside.
