im bored, lsx swaps
I thought about it but then I swap an lq and t56 for about $2500-3500 or more and have stock power.
Or I could spend that much and have a built 355 w/ heads/cam. For someone who's not so hardcore into it, it's not worth it.
Come on man. By the time you're done and have it running, you will have spent more $$$ than just doing an all out, ***** to the wall, LT1 383/396
But good luck bro. The Best V8 Stories One Small Block at Time
Still a tuff decision Nitro LT1 vs. Lq9 block LS.
For me the MPG w/ a close to stock cam is what will likely be a deciding factor. I know the LS def makes more hp but is it def. better at gas mpg'z while doing so?
I've been leaning on LT1 for some time now becuz it seemed the better mpg performer and becuz I have it already. But I hadn't truly confirm'd mpg.
But I read on a different thread. If you have a T56 already...you don't neccesarily need to swap it. You should be able to swap out the input shaft and front cover. Thereby converting your older T56 to match to the LS engines. So cost goes down...but I'd want to refresh my old 1 it needs it.
The only questions would be how much better internal design is in the later T56's? And can we keep our clutch forks rather than go with the later hydraulic clutch throwout? and if not...how bad is the later version clutch throwout problems?
Ah but dude at under 5 grand your gonna be dealing with a real pos worn out LS. and tranny....putting u right back where u started.
not sure but if I went this route.....the nickel and dime route would likely be the way.
becuz inheriting a whole other car with its own problems doesn't mean I wont have to work. plus I can nickel and dime it slowly....like start the motor and take my time....gather all parts and then when its all ready round up the last pieces for the T56.
Anyone know if later T56's are SOOOOO much better than olders?
