Help!!!!! 95 camaro trouble
Old 02-23-2011, 10:11 AM
License2Ill's Avatar
This is NOT the tune...thats a relatively small cam. u can come close to that w/ stock cam and 1.7 roller rockers.
Some one else already posted this. But i'll ask as well.
Have you replaced the ICM? its about 90 bux....but it does everything u've mentioned when it fails and sometimes does NOT throw a code. who knows why ?
Outside of this where did u get your replacement opti?
Old 02-23-2011, 10:22 AM
831jd's Avatar
ill check the ICM again. and opti we replaced it with a msd
Old 02-23-2011, 10:24 AM
831jd's Avatar
Originally Posted by quik95lt1
backfiring through the intake or exhaust???
did you burn a plug wire???
it back fires threw the exhaust. we replaced all the wires with msds
Old 02-23-2011, 10:32 AM
quik95lt1's Avatar
sure you dont have 5 and 7 crossed????
Old 02-23-2011, 10:36 AM
831jd's Avatar
im pretty sure but ill check thanks..
if money is tight....and u have a friend w/ working LT1...swap out ICMs.
Old 02-23-2011, 10:45 AM
831jd's Avatar
lol i was just thinking about that. im going to swap my uncles icm off his lt1 when he gets back from work he has the car
Old 03-03-2011, 08:00 AM
How'd it go? icm or coil?
Quick Reply: Help!!!!! 95 camaro trouble
