Oil Pump
Old Feb 23, 2011 | 01:03 PM
gregrob's Avatar
Default Oil Pump
What are you guys running?
And before someone suggests it I don't want a cheap piece of **** melling.
Clearances will be fairly tight so stock volume is fine
Im honestly considering a new GMPP pump with white relief spring?
Will be driven with an ARP hardened shaft coupled to a Heron Billet drive and Lunati Everwear gear.
Old Feb 23, 2011 | 01:15 PM
SS RRR's Avatar
Village Troll
Running a GMPP pump would be fine with the high pressure spring. Then spray it.
Old Feb 23, 2011 | 01:22 PM
gregrob's Avatar
Of course.
What about the moroso race pump standard volume?
I've heard of the blueprinted morosos buy can only find a big block part number. Nothing for sbc
Old Feb 23, 2011 | 01:33 PM
SS RRR's Avatar
Village Troll
I has no idear...
What kind of RPM are you going to run?
Old Feb 23, 2011 | 01:40 PM
gregrob's Avatar
7k til I swap PCMs
Old Feb 23, 2011 | 01:42 PM
quik95lt1's Avatar
greg i just bought the moroso blueprinted race pump (not the billet one) for my motor.......looks like a nice piece and they're telling me it will actually live above 7000rpm........i had the melling in mine but when i took it out it looked and sounded a little crapppy....called melling and the guy almost **** himself when i told him i was taking it to 8000+ rpm lol.............the moroso looks nice for $80 or so
Old Feb 23, 2011 | 01:43 PM
gregrob's Avatar
Awesome. Do you have a part number?
Old Feb 23, 2011 | 01:44 PM
quik95lt1's Avatar
yea hang on
Old Feb 23, 2011 | 01:47 PM
quik95lt1's Avatar
heres the one im running........
http://www.summitracing.com/parts/MOR-22111/
if you want a standard volume its MOR-22101
Puck's Avatar
Was it the standard 4 digit Melling or the Select series 5 digit ones?
Never heard of a problem with a stock vol/psi Melling Select like the 10554.
Old Feb 23, 2011 | 01:49 PM
quik95lt1's Avatar
it was a MEL-155HV one of their high volume pumps.......when i took it off the gears had some noise when i spun it by hand......too it apart and the gears looked a bit odd.......melling told me its not designed for high rpm use like i was doing with it....
would've been shitty to launch my motor because of a $40 oil pump...........
Old Feb 23, 2011 | 02:27 PM
fex77k's Avatar
Does anyone have experience with a titan.
Old Feb 23, 2011 | 03:25 PM
gregrob's Avatar
Karl Elwein uses the Titan. I got mixed results on yellowbullet from it. Most said the Moroso billet was better. FWIW
Old Feb 23, 2011 | 03:28 PM
gregrob's Avatar
Cool. Thanks
Old Feb 24, 2011 | 10:32 PM
gregrob's Avatar
I decided to go with the GMPP Std Vol High Pres Pump
12555884
