LT1 head casting numbers?
Old Feb 23, 2011 | 09:32 PM
93M6Formula's Avatar
Default LT1 head casting numbers?
Hey I have a question about LT1 heads.
Is there any of the aluminum heads that are a better casting or anything like that? or are they all the similar?
Thanks
Aaron
Old Feb 23, 2011 | 10:48 PM
Gojira94's Avatar
Lots of info on this out there- the 10128374 and 10207643 are the ones AI will port for you. the 561 castings are ok for porting, but flow best as-cast vs the older 2 castings from 93-95. If you want the best as they popped out from the factory, try the 561s. If you want porting from mild to max effort, go with the older 2 castings or go aftermarket if you prefer.
Old Feb 24, 2011 | 08:31 AM
Okay good to know, I have the 374's on my car now and was just curious.
Old Feb 24, 2011 | 09:43 AM
nitrous2fast's Avatar
which casting came on the 97's?
Old Feb 24, 2011 | 11:09 AM
ZGOBYBY's Avatar
I believe 374s came in 97's.
Old Feb 24, 2011 | 12:34 PM
Gojira94's Avatar
96-97 were mostly the 561s. 374 was a 93-94 casting, IIRC.
Old Feb 24, 2011 | 12:53 PM
Sounds right cause my '93 has 374's.
Old Feb 24, 2011 | 01:04 PM
Gojira94's Avatar
I have a pair of 374s and a pair of 643s ready to go to AI. Tax refund is for ***** this year so it'll have to wait until summer, since I also need a $680.00 stall, $300.00 for rear gears & installation kit, $240.00 rockers, $300.00 cam to make it all work.
Old Feb 24, 2011 | 01:10 PM
I hear ya, I kept thinking all winter I was gonna go ahead and get my heads done and buy a cam. Then I remembered all the little pieces that have to go with it, tune, rockers, poly locks, guide plates, gaskets, injectors, you know the rest.
Suddenly it wasn't so cheap anymore
Old Feb 24, 2011 | 01:39 PM
wrd1972's Avatar
Old Feb 24, 2011 | 02:06 PM
ZGOBYBY's Avatar
Oh, okay. Thanks for the correction. I know I had 643s on my '95.
