benchmark numbers
Stall is downed to 3600 because of the deal I got on one lol
But the guy with the Mustang said it his car runs low 11's and sure as hell think it does.
Looks like ima have to bring the bottle to run with him lol.
And sure we can race??
specs
234/244. 579/575 110 LSA
LE2 heads
4000 VIG stall
3.73s. In the back
38 pound injectors
LE2 intake
weigh around 3400 pounds
guy at work has a mustang and want to run with it and rode it and omg the bitch flys and want to run with it
here was mine
234/242 .600 108LSA from AI
Unported Trick Flow 23* Heads
4000 Vig Stall
4.11's Out back
36lb injectors
AI Ported Intake
and 3450lbs
the car always hooked good i ran consistant 11.4-11.6 @ 119-122 with the car.....
It bested a 1.47 60' 7.2 @ 96 1/8th and 11.40 @ 122.1
i would think you'd be close to that......you prob have a little more cyl head than i did before
sounds like it should move out good once you get it all dialed in.....hope to see it at the shootout
here was mine
4000 Vig Stall
4.11's Out back
36lb injectors
AI Ported Intake
and 3450lbs
Maybe the 2012 shoot out haha plan to have it done in November so won't be able to make it up there unless something crazy happens. mid 11's would be great for the car. It might start as a DD but I keep thinking its going to end up being a Tin can when I'm 100% done with it
