Whos using ATI Super Damper
Old Feb 25, 2011 | 08:37 PM
Money1's Avatar
Is the hub included with the balancer
Old Feb 25, 2011 | 09:09 PM
GIZMO's Avatar
I use ATI dampers on all of my motors. The quality is second to none.
If you put the hub in boiling water before installation, it goes on much easier.
They are quite a bit lighter than stock. Especially if you run the aluminum hub.
Old Feb 25, 2011 | 09:21 PM
gregrob's Avatar
Darren, would you suggest the aluminum or steel hub for me.
7000 RPM, M6, big shot of nitrous.
Thanks
Greg
Old Feb 25, 2011 | 10:31 PM
fex77k's Avatar
Thanks
Greg
Aluminum if you have the coin. I have a steel one but either one is great.
Old Feb 25, 2011 | 10:56 PM
Lonnies Performance's Avatar
LS1TECH Sponsor
Personally I would not run the aluminum hub on a street car. Wear of the seal area can be an issue long term.
Most of the weight savings is realized in the shell
Old Feb 26, 2011 | 02:36 AM
355z28's Avatar
What type of gains are here? since its lighter then stock it cuts down on rotating mass right? would it be a noticable gain?
Old Mar 7, 2011 | 08:54 AM
James Montigny's Avatar
I bought one two years ago, it's been a great addition.
It slides on and off with proper tools and without frustration and looks great.
The timing marks make adjusting rockers easy too
Old Mar 7, 2011 | 03:39 PM
ElkySS's Avatar
im curious, what would be the advantage of running this dampener over the under driven solid one from jegs thats half the price?
Old Mar 7, 2011 | 04:42 PM
fex77k's Avatar
Quality, the first time you pull the balancer on the hub you will understand. There are cheaper alternatives, but this isn't where you should save money.
Old Mar 7, 2011 | 07:37 PM
BOLO's Avatar
So what part # is the all aluminum piece?
Old Mar 8, 2011 | 10:26 AM
ElkySS's Avatar
i mean as far as actual function. does the ati weigh less? is it gonna run with less vibration? whats the big deal? im trying to justify buying a balancer that expensive
Old Mar 8, 2011 | 11:00 AM
  #32
fex77k's Avatar
You can purchase different shells and hubs for the assembly, you can also attach a flying magnet or something more serious like a blower hub.
The shell is able to be rebuild, so it should be the last balancer you buy.
Old Mar 8, 2011 | 11:10 AM
  #33
ElkySS's Avatar
so what kind of improvements would i see on a daily driven na 396?
Old Mar 8, 2011 | 12:33 PM
  #34
fex77k's Avatar
Reduction of your "Moment of inertia" on your rotating parts.
Old Mar 8, 2011 | 12:47 PM
  #35
Wicked94Z's Avatar
I run the 10% under jegs piece... I got it on sale and it is a good quality unit, definitely blows the stock pieces out of the water. I use it with a mallory crank trigger (they're all the same anyways) and the only difficult thing is centering the crank trigger since there's no real way to register it on the stock style balancer. I used some ~3/8" spacers and some trial and error. Ended up probably ~.005" off center but I can live with that, the gap ain't too sensitive on these crank triggers.
Old Mar 8, 2011 | 01:01 PM
  #36
gregrob's Avatar
The damper is also a very important part of the valvetrain, most overlook that part of it. That in addition to what mark said is why its a must on my engine.
