EVAP canister purge solenoid valve DELETE and air DELETE
Doing the wire relocation mod and AIR delete and I broke the hard vacuum line from the canister to the canister solenoid valve, so I want to delete it all.
![](http://shbox.com/1/evap_sol.jpg)
Im assuming with it unplugged it will throw a SES light...will it affect anything performance wise? Does anyone know what resistance it is expecting across the terminals, if I just soldered a resister between the 2 wires to make it think everything is OK.
Can I just cut the purge line at the canister and just let it vent to atmosphere? Or should I remove the canister all together using the "just pull the top and bottom until the canister comes out, youll feel like its breaking but its not" method. Then how do I vent the tank?
With the AIR delete, the 3 wire went back to a little module below the ABS block, with a 2 wire that went to that module, with 1 vacuum line from the AIR pipe. Shoebox doesnt show it, what is that module and what will happen now that its gone?
The best thing to do would be to have it programmed out. I have read several threads of folks trying to measure the required resistance, and the PCM still bugs out about it.
You can let the line vent to atmosphere sure, but it will produce a fuel smell. I would recommend removing the line at the rear of the car and put a small filter on the end of it (to prevent particulates from entering the line). The fuel smell would really suck at the front of the car, blowing into your windows while you're moving.
What you are describing with the AIR pump is the additional AIR pump recall components. shbox.com has it on his site. You can still delete everything just fine - just leave a good fuse in the system.
No, it will not affect anything performance-wise, aside from the fans being on all the time.
As I've said before a 94 will NOT throw any codes OR run the fans all the time. Not sure where you're getting this
