ABS & ASR Light On...Help Me Cut It Off...
Old 02-26-2011 | 12:50 AM
SmartOJ's Avatar
Default ABS & ASR Light On...Help Me Cut It Off...
ok guys my asr and abs light has been on since i bought my car and i would like to cut it off as long as it doesnt break the bank.i managed to get someone to put a tech 2 on it and got DTC C1256 which is left front ABS Motor Circuit Open. i tried to search on here and google it,but i cant find any info on it pertaing to my car which is a 1996 z28 m6.
can any of the techies point me in the right direction....does that codehave to do with the wheel sensor by any chance?
Old 02-26-2011 | 08:41 PM
SmartOJ's Avatar
anyone?
Old 02-26-2011 | 11:40 PM
86formula's Avatar
take out the cluster and pull out the bulb
Old 02-26-2011 | 11:50 PM
Vexzer's Avatar
Give it a shot. Take a look at the sensor, unplug & replug & see if it clears.
Old 02-27-2011 | 04:36 AM
nascarnate326's Avatar
Look in your fuse box under hood. There is a abs/asr relay that could be bad. Does your car have a good battery?
Old 02-27-2011 | 12:46 PM
SmartOJ's Avatar
yea "smarty pants" pulling the bulb is an option but having ABS & some traction control would be nice...as of now im coming up with the ABS motor pack may be malfunctioning.we have a few pull apart yards here in town but i need a diagram on how to remove it and some resistance readings on the motor pack so i can find a good one....this is one of those threads where i need shbox to chime in...where you at lol
Old 02-27-2011 | 01:42 PM
CBR Crazy's Avatar
I have the same thing going on. Try checking the wiring . I have a broken wire on the rear left sensor and that made mine come on. Just need to cut and splice new piece in and all is good. Had a gm tech of twenty years help me out . He said it is a common problem.
Quick Reply: ABS & ASR Light On...Help Me Cut It Off...
