Installed aftermarket overflow container...issues...
Old Mar 1, 2011 | 03:46 PM
Black94Z28's Avatar
Default Installed aftermarket overflow container...issues...
I picked up one of the plastic summit overflow containers since after doing the battery relocation, the stock container looked out of place. Anyways Ive been noticing that I fill up the radiator with coolant drive the car for a day or two and then 1/4 of the coolant drains into the overflow tank. Any reason for this? I have to keep emptying the container back into the radiator.
Old Mar 1, 2011 | 03:50 PM
05HD's Avatar
Probably because you don't have it recirculating. The hose from the filler neck needs to go to the bottom of whatever can you have.
Old Mar 1, 2011 | 04:45 PM
Black94Z28's Avatar
Hmmmm...yeah I had the tube come from the top of the container. So I should basically flip it over. Although the bottom has a lever switch to empty the container.
Old Mar 1, 2011 | 07:20 PM
jaycenk's Avatar
Is the container vented? also have you replaced the radiator cap? if so is it an 18psi cap?
Old Mar 1, 2011 | 08:49 PM
Black94Z28's Avatar
yeah, the container has a small vent hole up top. Cap is factory.
Old Mar 1, 2011 | 09:24 PM
05HD's Avatar
Yep. Sounds like you got a catch can, not a recirculating overflow bottle. If you put the hose on the bottom and leave the lever open, it will work fine, as long as it is big enough to hold the amount of coolant that comes out as the system comes up to temp.
Old Mar 1, 2011 | 09:32 PM
Black94Z28's Avatar
So just hook the line up to the bottom lever and plug the top part?
Old Mar 1, 2011 | 09:33 PM
05HD's Avatar
Yep. Or you can run a hose from the top off somewhere you would like coolant to go if it overflows the tank for some reason.
Old Mar 1, 2011 | 09:37 PM
Black94Z28's Avatar
Thanks for the advice...I did not know you needed the line hooked up at the bottom of the container.
Old Mar 1, 2011 | 09:53 PM
SoxXpupPeT's Avatar
yeah i found that out when i did the same thing. I hooked the hose up to the bottom and all is well
Old Mar 1, 2011 | 11:07 PM
gregrob's Avatar
You didn't reverse the hoses on the radiator did you?
I wouldn't think it would be puking into the overflow all the time, as it has to overcome the seal of the cap to push coolant into there. Something that shouldn't be happening on a regular basis IMO.
Old Mar 1, 2011 | 11:14 PM
the_merv's Avatar
Post a pic..
Old Mar 4, 2011 | 07:29 PM
Black94Z28's Avatar
put the stock tank back in and drove the 50 mile round trip with no issues, so it must be what was stated above about the line needs to go to the bottom of the overflow tank.
Old Mar 4, 2011 | 08:08 PM
the_merv's Avatar
Yes, it needs to be able to draw it back out.
Old Mar 5, 2011 | 07:38 AM
SoxXpupPeT's Avatar
yup. the same thing happened to me.
Old Mar 5, 2011 | 12:18 PM
05HD's Avatar
The block and heads expand when they are hot. Less room for coolant = it pushes some out and sucks it back in when it cools off.
