What does this combo of codes mean....
36 Distributor ignition system (faulty high resolution pulse or extra low resolution pulse detected)
42 Ignition Control (IC) circuit (shorted or grounded circuit)
44 Bank 1 (left) Heated Oxygen Sensor (HO2S) Circuit (lean exhaust indicated)
What thing or combination of things could this be? Brand new motor, ALL brand new parts... MSD opti, MSD coil... heated 02 conversion with new Delco 02's.
ICM is new or old? Have that tested at AutoZone and have them run the test several times in a row so it can get warm and fail if it's going to
O2s- clear codes, swap sides and see if it switches to the other bank.
Good places to start...
The other day I couldn't get the car out of the parking lot before it happened, and it wanted to shut off.
The ICM is the coil right? The coil is a brand new MSD blaster. The opti is brand new MSD, new harness all connections are clean and good...
