ABS inop light
I had also removed the EBCM (ABS computer under te dash) thinking this was going to keep the ABS INOP lamp off, but no!
Due to the fact that my car is a 96 Camaro and the instrument cluster is a bitch to remove without breaking the dash cover, lamp removal was not an option.
Well it turned out real easy. Just locate terminal No A7 fom the EBCM C1 connector (24 terminal connector) and ground it with a small wire.
If you dont unplug the connector you can cut the wire and ground it. Ground the wire going to the dash, not the wire into the EBCM.
