Holley Stealth Ram!
Holley Stealth Ram!
Break out the cutoff wheels
I also picked up a new set of stainless stepped longtubes (no ebay junk ) to replace my pacesetters which have seen better days I need to "trim" the cowl before my intake gets back from the shop. Before I run the intake I need to have my buddy raise the ports about ~.08" to match up to my heads which are ~1.26x2.28. New cam specs are a tentative 258/264 on a 109+4, lift is .680/.660. I have some new beehives, and lightened titanium retainers on the way!
Pshh, throw the plenum in the trash and just drill the plate for 4150 bolt pattern and run dual Wilson 4bbl TB's! That would be sick!
Can't wait to see you shoehorn that thing in without welding/cutting the runners, its gonna look insane .
::edit:: Also cant wait to see results from the modded OptiTrigger/PCM mod and that huge HR cam .
Oh yea, I paid 500 for the whole setup
I'm doing the cam on this one, I just need to get ahold of John over at Comp to make sure he has a good small base circle core that will work for what I'm trying to do. HR... it's just an experiment. Everyone assumes they need to jump to a SR and I'd like to push the envelope on a beehive spring.
PM sent btw...
PM sent btw...
Village Troll
PM sent btw...
PM sent btw...
I wanted a longer runner (auto), I wanted a bigger runner (cubes, E85, nitrous) and I wanted plenum volume (all of the above). I wasn't set on the HSR, I just happened upon this one on RJ and decided to go for it, the price was right. The nitrous... I've been wanting a DP for a long time.
Headers are nice, clean, unrusty ones
I have nothing against the HSR don't get me wrong, we have it on my cousin's 92 z28 and its works badass, but you are going to be doing alot of modification to get that HSR to fit.
I would say the miniram but I haven't had any luck with the miniram. A buddy's of mine vette caught fire at the track from a leaking fuel rail.
Good luck with the HSR install and keep posting pics I'd like to see the end result.
It's a pretty definite no right now. I'm about to be in the middle of moving... I'm trying to get this motor work done in the next 2-3 weeks, then not sure how long before I'll be able to work on it because my garage will be all packed away in storage. Besides I'd be stuck in Mod PA with all the fast guys
This just my opinion but since you were changing the cam anyway I would think a converted vic intake with a 4150 TB would be a good choice with all the compression, cubes, converter and gear you are running.
Intake is at the machine shop, I've gotta add ~1/4" of weld on top of the runners (TALL raised ports on the AFRs). I'm having the middle holes redrilled, and the corner holes corrected for the lt1 bolt pattern, so only 8 bolts will be used. The thermostat housing is being shaved off, the height of the tunnel ram should stand out pretty good now with all this welding on the manifold I'm having him machine all the surfaces to match my lt4 which was leak free.
