true dual slip fit install question
I have pacesetter lt's installed and I am about to start on the rest of the true dual exhaust. My only problem is going from the 3 inch slip fit collector to the 2.5 inch tubing for the rest of the exhaust. I've seen a few people weld flanges onto th e collector which I'd rather not do. What are my other options?
One like this:
http://www.summitracing.com/parts/WLK-41974/
Also get a nice pair of 3" band clamps:
Like this:
http://www.summitracing.com/parts/SUM-692300/
The band clamps suggested above are great for slip fit, I run 4 on my TD setup.
http://s38.photobucket.com/albums/e1...ual%20Exhaust/
I've had a 100% welded dual setup before, it's great until you have to drop the tranny or replace a head gasket.
I had flanges on my hooker LTs, I hated them. I couldn't get them to seal properly.
Im looking at buying some pacesetter LT headers and noticed that they wont have a flang. The band clamps are somthing ive been suggested to use before and by looking at them in the pictures above they look easy to work with. What about exhaust leaks? Do they seal up well?
Well they should supply stainless hardware with the stainless clamps. I have had a set rust so bad I couldn't get the bolts out, just got new hardware and it was good as new
