FPR Took a Dump - which one to replace?
Old Mar 9, 2011 | 08:08 AM
DAVE00's Avatar
Default FPR Took a Dump - which one to replace?
Well guys my Adj FPR finally took a dump and found out last night when I took the vac line off and got a strong smell of gas. Guess the diaphram is finally gone. No wonder I've had a strong fuel smell and also major issues tuning this biotch. We'll I'm gonna get a new one, and I'm looking at the following:
Holly 512-502
or
Aeromotive 13107
Which one do you prefer?
Also, any sponsors here that sell these suckers or do I need to stick with Jegs/Summit?
Old Mar 9, 2011 | 08:09 AM
SS RRR's Avatar
Village Troll
Stock.
Old Mar 9, 2011 | 08:19 AM
DAVE00's Avatar
Originally Posted by SS RRR
Stock.
Doesn't having an ADJ model allow for better tuning/dialing in the PSI, esp with my cam size and different injectors?
Old Mar 9, 2011 | 09:00 AM
speedracer2536's Avatar
I like the fuel lab regulators.. Not sure if you have the stock rail though.. If so i would go with aeromotive
Old Mar 9, 2011 | 09:05 AM
DAVE00's Avatar
Yup, I have the stock rail, anyone have experience with the holley model?
Old Mar 9, 2011 | 09:13 AM
SS RRR's Avatar
Village Troll
Injector size/rate is tuned via PCM. The injectors you use should operate on stock fuel pressure which is between 43 and 45psi (specifically written as 43.5psi via GM) which is where a stock regulator operates at.
Old Mar 9, 2011 | 09:16 AM
jaycenk's Avatar
Like SS RRR said I would go stock unless you are using a wild set up with custom rails and high flow rate injectors that need to be dialed in. The tune is usually done with the stock pressures in mind so if its off the injector will inject a different amount of fuel.
Old Mar 9, 2011 | 09:26 AM
DAVE00's Avatar
Thanks SS, yup everything in my tune is dialed in for these injectors. Now, that will save me some $$$, so I have a hookup at AdvanceAuto Parts, what do you think of the BWD OE replacement?
Old Mar 9, 2011 | 09:30 AM
qc97z's Avatar
Stock.
^ This.
Unless you're boosted, stock is all you need.
Old Mar 9, 2011 | 09:35 AM
SS RRR's Avatar
Village Troll
I have no idea. I don't have warm fuzzies regarding aftermarket replacement parts right now. I just replaced my radiator with one from Autozone and all the hose ports as well as the tabs for the low coolant sensor are smaller. I had to get hose clamps for everything connecting to the radiator most everything was leaking.
Instead of going with something from a parts store made in Mexico, I'd probably opt for one from GM which is most likely made in Mexico, that is if it hasn't been discontinued...
Old Mar 9, 2011 | 09:42 AM
jaycenk's Avatar
I used that one on mine it works great. Just check it with a fuel pressure gauge to make sure it works right before you rely on it.
Old Mar 9, 2011 | 10:05 AM
DAVE00's Avatar
Cool - thanks.
I've had this ADJ model on here since 99' when we built the motor and it's the Accel model that looks stock with an allen screw for adjustability. Don't think I can rebuilt it so I'll get the OEM replacement.
Old Mar 9, 2011 | 10:14 AM
lttransam's Avatar
i have the holly and love it. fixed all my problems.
Old Mar 9, 2011 | 12:11 PM
SPOT ME 3's Avatar
Just bought an adj. BWD for $60 at O'Reilly
Old Mar 9, 2011 | 04:25 PM
RamAir95TA's Avatar
Stock. I've said it before, but an adjustable fuel pressure regulator is one of the most misunderstood and misused parts. It is rarely a necessity, not to mention several of the aftermarket units have been known to leak - extremely dangerous of course.
I have the stock 120k mile regulator on my car and have no intentions of changing it.
Old Mar 9, 2011 | 04:30 PM
BizZzatch350's Avatar
Moderator
Dave,
If your in a bind I got a Aeromotive one, brand new in the box for 94+ rails. If you need it let me know, you can just order one and give me that one. Or just pop this one on and see if thats your problem.
Old Mar 10, 2011 | 09:49 AM
DAVE00's Avatar
Originally Posted by BizZzatch350
Dave,
Thanks Neil, I really appreciate that. However, I just picked up the BWD OE unit today from Advance and I'm gonna give it a shot this weekend. I'll let u know how it goes. Don't really need the adjustability so we'll see.
Old Mar 11, 2011 | 02:08 AM
madhatter's Avatar
I replaced mine with a Delphi from Napa. Most likely the stock piece.
