Last edit by: IB Advertising
See related guides and technical advice from our community experts:
- Camaro and Firebird How to Replace Brake Master Cylinder<br>Step by step instructions for do-it-yourself repairs.
ls1 master cylinder on our cars?
my master cylinder is leaking a little so i need to replace it, i found a really nice one off of a 02 TA and was wondering if it would work? the boosters are the same from 93-02 but is the master cylinder? i dont have abs or any of that crap if that makes a difference. thanks!
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
LS1 brake master cylinder will NOT directly bolt up the rear brake line but it will bolt to the booster. The rear LS1 line fitting is larger on the LS1 master and the LT1 line will not fit it without making a whole new rear line from the LS1 MC to the prop valve.
Also the flow valving is different on the rear circuit of the LS1 MC compared to the LT1 MC. You can expect the pedal to feel a little different if you do this but I assume it would work.
Views of the rear flow circuits. LT1 on top LS1 on bottom.
![](http://i140.photobucket.com/albums/r6/wrd1972/IMAG0128.jpg)
Front flow valving is the same on both.
how many miles on it? mine only has 110k but is leaking some how.
yes.. ill take a pic tomorrow of the back of the master and you can see alittle bit of brake fluid.. and there is a spot under my master on the booster that was all bubbled.. but like i said the brakes felt fine 89% of the time and once and a while you would step on it, and it wouldnt be there. .
That's MISTER MODERATOR
LT1 master cylinders have a residual pressure valve to help overcome the springs in the rear calipers. LS1 master cylinders do not have this.
Using a LS1 master cylinder with LT1 rear brakes will cause your brake pedal to almost drop freely the first inch before "catching". This is because the rear caliper springs will pull the pads all the way back without the residual pressure. I experienced this when I went back to LT1 rear brakes on my '99. I had to use a LT1 master cylinder. I used the LS1 reservoir to accommodate the level sensor and made up my own line to get past the one different fitting.
The master cylinder in 4th gen F-Body cars must match the rear brakes.
I went to the LT1 rear brakes to clear 15 inch drag wheels.
I have an LS1 master cyl in my 1996 LT1.
I dont feel any difference in terms of pedal travel, but I have deleted my ABS with the SJM kit and have the proportional adjuster in the line going to the rear brakes.
Good info. I put LS1 rear and front brakes on my car last year and am still running the LT1 master. The brakes never quite felt right so while i currently have the engine out and am doing the ABS delete I planned to install a new LS1 master. Hope this makes a difference.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
good info thanks! i also have a proportioning valve so hope that helps me out.. like i stated above, i will have ford brakes in the rear lol.
Totally disagree. A little seepage IMO is not normal and indicates the rear o-ring is allowing leakage and therfore the MC is shot.
Then how come 50% of cars with brand new or not have Fluid in the piston seal area in the back? how come most brand new master cylinders come with a paper thats states that some brake fluid by the rear piston seal area is normal and does not indicate a leak. Im looking for the paper right now. I install masters all the time and seen the paper many many times. Thats why i then asked if the pedal was spongy or not, the pedal could be perfect never had a problem and have a very slight fluid around the seal area. I have seen guys change 3,4,5 of them just to still have fluid back there. the pedal does not drop at all or feel diffrent at all either. But im sure im wrong and your right and sorry to waste your time.
Dont get butt hurt, I clearly stated it was my opinion. I am confident in saying that GM engineers would not consider this normal because the introduction of even a minor amount of air into the lines might have an impact on braking performance or at least at a minimum, will introduce moisture into the brake fluid which will result in it deteriorating quicker than it should. Again this is my opinion.
