Tune help?
Old Mar 12, 2011 | 01:57 PM
sempire's Avatar
Default Tune help?
I just got around to installing my PCMFORLESS tune this morning, and after I started the car I got the check engine light and it was idling about 2000rpm. Also notice that the exhaust was really white, and trying to drive was a bit hard cause it would big down around 4000rpm.
I have a 1993 TA. any suggestions?
EDIT: spent another morning outside Doing it under a microscope and managed to get it working. The car feels good now, and I'm happy with this tune! Thanks!
Old Mar 12, 2011 | 02:04 PM
gregrob's Avatar
Not at all uncommon from them. Worst LT1 tuning anyone could possibly use IMO.
Call and request that they give you what you paid for. A tune
Old Mar 12, 2011 | 02:23 PM
sempire's Avatar
Oh man, really?
Old Mar 12, 2011 | 02:28 PM
95 mystic ls's Avatar
Haven't heard anything good about them in a LONG time.
Old Mar 12, 2011 | 03:57 PM
jaycenk's Avatar
Can you scan it?
Old Mar 12, 2011 | 05:21 PM
sempire's Avatar
Originally Posted by jaycenk
Can you scan it?
Maybe if I knew how. I'm kinda bleh at the fact that everyone is saying their tune sucks. It was on here where I was referred to them...
Old Mar 12, 2011 | 05:43 PM
jaycenk's Avatar
Do you still have the 93 ecm and harness in the car? For a 93 all you have to do is short 2 pins in the diagnostics port and it will flash the check engine light in codes to give you trouble codes. I don't know which ones but I am possitive there is info on the web on how to do it. PCMs for less in one of the few who do proms. I used madtuner. He can proms as well. If you have problems I would check the codes first and see what it says and also check your fuel pressure. Checking the fuel pressure on these cars is kinda like getting your blood pressure taken. It may have nothing to do with your illness but they check it anyway. lol anyway once you check the codes I would call them and see what they say unless the codes show you something else is wrong.
Old Mar 12, 2011 | 05:57 PM
lt1-xjs's Avatar
There are two addresses for pcmforless, the one you need is Moorseville,NC. Contact Alvin: You have no list of mods, stock, bolt-ons, cam ? I've run his bolt-on tune 7 years and have no complaints. He later corrected my a/f ratio once after a mod or two. I've run a best of 12.82 @ 3900 lbs.
Old Mar 12, 2011 | 07:41 PM
93z28ltone's Avatar
top 2 pine on the right side are the pins u use to get the codes to flash at u use a paper clip to jump them the check engine light will flash a code 12 at you 3 times then what ever your throughing a code for
Old Mar 12, 2011 | 08:31 PM
RamAir95TA's Avatar
They seemed to tune mine just fine. I've used them half a dozen times over the past 10 years.
Old Mar 12, 2011 | 08:36 PM
sempire's Avatar
I'm not doubting their work, as I said, a lot of members here recommended them. It was done by Alvin I believe. I am just wondering if there is something else I need to do? It's a 93. Do I need to unplug the battery? let it run for a while longer? adjust the tps? adjust the iac? i am not sure.. i was just hoping i can plug it in and have it work
Old Mar 12, 2011 | 08:48 PM
WS Sick's Avatar
was it a piggy back chip or the whole module?
If its a piggy back unhook the battery and verify the instalation of the piggyback.
Ya shorting the two upper left terminals of the ALDL connector , turn the key to on -no start, and count the flashes, it will repeat the flashes 3 times.
Old Mar 12, 2011 | 09:00 PM
jaycenk's Avatar
Was it running fine before the tune and why did you have it tuned? What MODS do you have on the car?
Old Mar 12, 2011 | 10:33 PM
lt1-xjs's Avatar
Disconnect the battery and check the installation again like stated above. This will also reset any codes. It will take a bit sometimes to re-learn certain perimeters.
Old Mar 13, 2011 | 07:55 AM
Alvin's Avatar
It sounds like you didn't install the piggy back chip with the stock chip or you did it in thr wrong orientation. That exact same thing happens when you only install the piggy back chip and not it with the stock chip. Check the little install sheet that was sent with it.
Old Mar 13, 2011 | 09:04 AM
sempire's Avatar
Hi Alvin!
Thanks for the suggestion, and the tune. I am very eager to try it out. I was just about to go outside and try again. I actually followed the direction precisely, made sure it looked like the diagram and read everything on your website. I double checked and triple checked your site to make sure there was nothing I was missing.
So, it turns out that one of the end pins on the main computer board was off by a hair so piggy back chip looked like it was in but wasn't, and after bending it to fit better everything was fine.
Thanks Alvin and everyone else here! I am happy with this tune!
Old Mar 13, 2011 | 02:34 PM
jaycenk's Avatar
Good deal. Hey I Alvin Great job helping him out on the weekend.
Old Mar 13, 2011 | 05:46 PM
Alvin's Avatar
Glad you got it taken care of! Thanks
Old Mar 13, 2011 | 07:56 PM
sempire's Avatar
I really appreciate the weekend help! I definitely recommend your service.
