Fuel problem maybe?
Old Apr 20, 2011 | 07:32 PM
  #41
lethal bird's Avatar
Originally Posted by Formula.Fx
Update:
Looks like I need a new fuel pressure sensor. I Don't have the cash right now but when I get it installed I'll update on if that was the main problem or not. lethal bird, have you looked into checking that?
I cant say that i have ever heard of a fuel pressure sensor.
Old Apr 20, 2011 | 10:38 PM
  #42
Ok well ive test all i know to/how to test, im just going to tow it down the road and have my guy look at it.
Old Apr 21, 2011 | 01:56 AM
  #43
the_merv's Avatar
Veteran: Air Force
Originally Posted by lethal bird
Do 95 lt1s even have a crank sensor because i couldnt find one.
No, not on a 95.
Update:
Who told you that?
Old Apr 21, 2011 | 02:00 AM
  #44
the_merv's Avatar
Veteran: Air Force
Originally Posted by the_merv
Maybe a loose wire or terminal.
Old Apr 21, 2011 | 07:17 AM
  #45
Formula.Fx's Avatar
Sorry - I meant fuel pressure regulator.
Old Apr 21, 2011 | 09:56 AM
  #46
Ive checked them all.
Old Apr 25, 2011 | 03:00 PM
  #47
Well i just got back. Tried a few more things and still nothing. It will start once and then run for about 15 seconds then die, so i tried to start it again and i flipped the key to engine off key on and fuel pump primed like it is supposed to then stopped, then 3 seconds later it started priming again. Does that sound like an electrical problem because i got to thinking maybe i shorted something when i tried to install the shift light i got because it all started when i got it put in and it didnt work? I ran the power wire to the radio power wire and grounded in the radio ground and the tach wire to the white wire that runs the computer under the passenger kick panel. If i cant figure it out before i have to leave again then im going to have to pull it to a mechanic.
Old Apr 25, 2011 | 06:15 PM
  #48
the_merv's Avatar
Veteran: Air Force
It primed up after it already had?
Old Apr 25, 2011 | 07:49 PM
  #49
Yes it primed then stopped like normal, then it primed again.
Old Apr 25, 2011 | 10:02 PM
  #50
my uncle said to check the relay. could it be that and still get pressure?
Old Apr 26, 2011 | 12:34 PM
  #51
Was also told to check the ECT sensor in the water pump. Can it does this I dont want to go buy a new sensor if i dont have to.
Old May 2, 2011 | 11:42 PM
  #52
Update. Got it scanned and pulled 16 low resolution pulse, and 36 high resolution pulse so it looks like it was the opti all along. Should have known.
Old May 2, 2011 | 11:54 PM
  #53
speedracer2536's Avatar
The opti has nothing to do with the fuel pump..
Old May 3, 2011 | 12:12 AM
  #54
Apparently you didnt read the entire thread. Next time read before posting ignorantly.
Old May 3, 2011 | 08:31 AM
  #55
I did read the thread.. Your fuel pump priming multiple times has nothing to do with the opti..
Old May 3, 2011 | 09:02 AM
  #56
LT1FirebirdSLP's Avatar
And the OPTI strikes again. It was only 1,500 miles old? Just a suggestion. Check that water pump, if the seep hole is leaking AF onto the opti, that will absolutely cause premature failure of the OPTI. You can tell if the WP is bad if there is visual fluid leakage, if it looks moist on the bottom, or if its stained/discolored on the bottom. I would sure invest in a new WP if this is the case. I can't think of any other reason for an OPTI to go bad after just 1,500 mi. Use new seals, and check for intake leakage at the front of the motor. Something caused that OPTI to prematurely fail.
Old May 3, 2011 | 11:11 AM
  #57
I was talking about the car not running, missing, ext, ext not the fuel pump issue.
The water pump is new and no leaks, I went cheap and got an an ebay opti(retarded i know but didnt have the cash for an ac delco at the time with going to college) and let go after a few to trips to the moon.
Old May 3, 2011 | 11:20 AM
  #58
Spend money on the new deal. Also, I read something about loctiting the rotor bolts. I would do a search and see what that is supposed to do.
Old May 3, 2011 | 11:29 AM
  #59
Yea i know like i said i was broke college student then. Ive done the research and it seems that its kind of a hit or miss thing. Some people say do it some people say dont.
Old May 3, 2011 | 12:14 PM
  #60
Formula.Fx's Avatar
So I just got word back from my mechanic. It turns out the issue with my car is a bad PCM. Time to dump some cash.
