LTX Cylinder Heads
Ported stockers are fine for most people, but aftermarket castings like TFS or AFR do have more overall potential for those few people looking to squeeze a bit more performance out of their builds.
Thats the paln.
I have to agree with you in a way. The AI LT4's are very comparable to the AI TFS's. There is only a 4.5 CFM intake increase in the TFS's over the LT4's, and a 2.9 CFM increase on the exhaust side. I don't think that would be much to relly make a difference. There is a $520 price difference in favor of the LT4's and the LT4's come with a cam. You just need a core for the heads.
The AFR 227's have a 24.6 CFM increase on the intake over the AI TFS 215's, and a 36.5 CFM increase on the exhaust side over the AI TFS 215's. If these numbers prove to be right I will be going with the AFR 227's. With only a $154 difference over the AI TFS 215's, the 227's seem like a winner to me.
There are other differences such as AFR's 3/4" deck and 60/40 valve spacing and slightly larger intake valve. The only downfall is that shaft mount rockers are almost required. Any other differences please let me know.
Michael
You don't need shaft rockers. You can run regular rockers with frequent checks (not recommended). You can order special stud rockers with an offset for around $300 right from AFR.
I have AFR 190s Old Old style on my 383 atm, I had them flowed new, with a valve job and later had some work done on them. They flowed within 3 percent of advertized (1995 numbers) numbers, but a valvejob and a back cut on the valves gave them 5 percent more almost accross the board. The set I have when new had CNC chambers and 1/2 CNC ports, When they were worked on by a local porter recently, they picked up a rediculous amount. They are in line with some of the better 200 cc heads I have seen here but with better exhaust ports. Total over the last 16 years of owning these heads I now have had them on 3 different engines and payed close to 3 grand ....lol (this is heads and head work alone, not springs etc.)
....and those cores are quite a bit of money.
LOL at the price difference. Don't be mislead by AFR's internet pricing policies. Basically they TELL their dealers how low they are allowed to advertise. The dealers can sell the heads for as low as they want to. Most will gladly send you a lower price through an email, but not on their website. Shoot me a pm and I will tell you exactly what I paid for my 227's. I will give you a hint....it was well under $2k.
. Hell, if I was going to dedicate all that money to a TT build I'd spend the cash on some converted AFR 230s and have Tony Mamo or Craig hand port em
. Also, don't forget that flow numbers don't always equate to performance. Look at LT vs LS heads for example. You can have an LS1 head that flows less then an LT1 head, but still make more power with a similar cam because they are much more efficient and maintain higher velocities.
For a turbo build in the power range you want, I would make ported AFRs my first choice and ported TFS heads like what AI offers my second slightly cheaper choice. You could run them out of the box for now, then have them ported for huge gains when you get your new pistons for the turbo build.
Michael
Michael
If you have them converted just tell them you are keeping a stock sbc style intake so they don't change the intake bolt pattern.
http://www.airflowresearch.com/index.php?cPath=27
Has or is anyone running a 4 bolt FRONT main cap from Pro-Gram. I was just curious because I have never personally seen this done. I always think the beefier and stronger the bottom end, the less problems. If it cannot be done nor is it that big of a dea,l then I will go with the Howard Billets for all 5 caps. Thanks
Michael
Michael
The money and effort would be better spent elsewhere IMO.
Just something to think about.
