I found another Bowtie Block (GM Race Shop)
#61
Okay....I know the obvious reply will be "why the (bleep) would anyone want to do that?" but looking at the pics and thinking about the differences got me to thinking.....if you are running an electric water pump (for a normal sbc) and not needing that part of the front timing drive, couldn't you run an opti on a GEN1 block with nothing more than an LT1 timing set and a custom timing cover that had the correct opening for the opti to seal into?
#62
Would be a whole bunch of bastardizing for a step backwards in reliability.
#63
LT1 timing cover wont bolt right up to an SBC, it uses an extra bolt with different spacing. Also, the SBC cam would need the correct length dowel pin and correct nose on the cam (retainer plate instead of thrust bearing).
Again, I know it isn't the most sane idea. I'm just thinking out loud.
