CC503 question
Timing cover gasket
oil/filter
water pump gasket set
RTV Sealant
Assembly LUBE (Ultra Slick Permitex wrks great)
Hub Puller
New Timing Chain Set (Sould replace this while replacing cam on high mailage car)
New lifters if car has over 75K Could use stock but risky and could have a falure
Harden Pushrods
Matching Valve Spring set
loctight
Valve cover gaskets (Maybe)
Roller Rockers 1.6???
Tune for cam
Coolant
This is just a quick thought of parts, you may need more or less.
Possibly throw an oil pan gasket in there as well, the timing cover sits in it, and it can possibly tear when you remove it. And any OEM/stock/factory connectors or harnesses that you break along the way, sucks alot, but i had some literally crumble when i touched them!
Timing cover gasket
oil/filter
RTV Sealant
Hub Puller
Harden Pushrods
loctight
Tune for cam
Coolant
http://www.cardomain.com/ride/229715...irehawk/page-4
96TransAmboosted's list looks pretty complete for a cam-only swap.
As for lifters ... you can probably reuse them if they look good.
However, lifters are a pain to get to and cost about $100.
If you want to change them out for peace of mind, I say go for it.
Send the old ones to Gregrob :p
Ok then, what "new" lifters would you recommend.
