Lets build a 383 ? "forum group effort"
#82
You don't wanna get a Fel Pro replacement set for an Impala because unless things have changed, it will have thick head gaskets and is the same as their F-body kit. You will be much better off to go with GM or Victor head gaskets and then just use Fel Pro for everything else like the intake, timing cover, valve covers, etc. It's usually alot cheaper going this route than buying a "set" for an LT1 anyway.
#83
ok, bought a forged 4340 eagle crank and they are balancing it ....
My melling select 10554 oil pump came in today from summit ...
so build parts check list,
prepped block @ 0.030 with new cam bearings
eagle H-beams and bearings
eagle 4340 crank and bearings
flat top srp pistons
ARP main stud kit
ARP head stud kit
SV SP melling select oil pump..
ARP main stud kit
ARP head stud kit
#88
PayPal ready
Michael
![The Judge](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_judge.gif)
Now on the hunt for a zero balanced flywheel and dampener?
#93
my eagle esp 4340 crank is here!! ![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
.. found out my brand new bearings that came with the cast crank are 0.10 rods and 0.20 mains ..so now i gotta buy bearings for the standard sized new crank
anyone need either set? clevite 77 h-series
#96
Yes the dampener is already 0 for lt1 and you only need to put a weight on the flex plate if the motor isnt internally balanced.
I also dont know how the crank could be balanced right without the rods, pistons and rings unless you sent them that info. I would also have the crank checked to make sure it doesnt need any additional work b4 putting it all together.
#97
Yea, my machine shop is actualy doing the balancing .. Eagle ended up wanting more to do it than locally available .. How about the ring gapping and position? Can u explain quench to me? Block is stock in deck height ... Stock head chambers 6" rods flat tops with 5cc reliefs.. This **** is confusing..
