Best Spark Plug Wire...
Old Apr 3, 2011 | 10:53 PM
SoxXpupPeT's Avatar
Default Best Spark Plug Wire...
Im just wondering what everyone runs ? I currently have MSD wires, but im going to be changing them out soon. Afew of them had some close calls with my header primaries
So what does everyone run for a stock location wire ?
Old Apr 3, 2011 | 11:04 PM
riceburnerZ28's Avatar
I'm using Jegs 8mm wires. They've worked great!
Old Apr 3, 2011 | 11:07 PM
robsquikz28's Avatar
msd and 10.4mm are both great
Old Apr 4, 2011 | 09:46 AM
AirborneZ28's Avatar
I went with the MSD 8.5mm Super Conductor 32149 wires on my 93 Camaro Z28 with stock routing. While the wires have been great and no heat problems with my headers (I have the high heat boot protectors on them) but I had to fight like hell to get them into that guide that routes them around to the passenger side due to their size. If you are thinking of running larger than 8.5mm you should probably consider an alternate routing. I do not know what kind of performance drop you would see by going to the 8mm MSD wires (or anyone's 8mm wires for that matter) but they would be alot easier to route through some of the tighter stock locations.
Old Apr 4, 2011 | 10:08 AM
killagt's Avatar
im using red taylor OTHVC, np
Old Apr 4, 2011 | 10:21 AM
RamAir95TA's Avatar
MSD 8.5mms here, routed in the stock locations.
Old Apr 4, 2011 | 11:31 AM
wrd1972's Avatar
MSD 8.5mm Super Conductor.
Old Apr 4, 2011 | 11:34 AM
GR33N GoblinM6's Avatar
Hmm I'm using duralast wires, so are a few people I know, no issues with them. Cars are mostly stock, one has a hotcam.
Old Apr 4, 2011 | 11:37 AM
glassjaw1704's Avatar
Summit 8.5mm with no issues here.
Old Apr 4, 2011 | 11:46 AM
Verz's Avatar
msds here as well and i also burnt the crap out of my cyl #7 wire, def needs replacing :/
Old Apr 4, 2011 | 11:58 AM
myltwon's Avatar
MSD 8.5 routed in all kinds of fun directions. running some under the motor mount definately helps.
no boots or sheilds here, just zip ties and running em whereever it works.
fex77k's Avatar
I'm running 8.5 in the non stock location, the only way they survive is with the fiberglass boots.
Old Apr 4, 2011 | 01:10 PM
TWS's Avatar
TWS
Same same. Had MSD's but some of them didn't Ohm out well this time around. We installed a set of Taylor's and did some very creative and careful routing, using about a dozen zip ties and going through motor mount on the driver's side.
Old Apr 4, 2011 | 01:14 PM
myltwon's Avatar
glad to see someone else running a similar route. I stole the idea from a friend and couldn't be happier. much easier and less time consuming to route and haven't had a single burnt wire problem since unlike before when I attempted to use stock routing.
Old Apr 4, 2011 | 02:26 PM
Either of you have some photos of those routings? I have mine tore apart right now doing plugs (see topic "Spark plug reading time" LOL just posted) and I would love to see some good ideas on routing.
Old Apr 4, 2011 | 03:31 PM
draggin97s10's Avatar
i use summits and run them with the motor mount zip tie method. always worked for me
Old Apr 4, 2011 | 04:50 PM
AChotrod's Avatar
MSD 8.5 SCs here
Old Apr 4, 2011 | 05:22 PM
Fazz73jr's Avatar
Taylor 8mm in stock location.
Old Apr 4, 2011 | 07:38 PM
SoxXpupPeT's Avatar
Wow im suprised about the comments this has gotten. and so far not a single fight! lol amazing!
Im not sure if i want to go with MSD 8.5 wires again or not. The boots always gave me a hard time with going onto the opti/plugs. i was leaning more towards the taylor/moroso/jegs wires
Old Apr 4, 2011 | 08:04 PM
myltwon's Avatar
lots people have had great luck with taylors, not me personally. I went through 2 sets that arched right out of the box.
