LT1 cam help
Old Apr 7, 2011 | 05:18 PM
Big Al's Avatar
Default LT1 cam help
This is the cam card that came with the car I bought. Good, bad or?
The cam is dead and I need to replace it.
Al
Old Apr 8, 2011 | 06:51 AM
RamAir95TA's Avatar
That's a pretty decent sized cam - too big to be used with stock heads IMO. What do you mean the 'cam is dead' and you need to replace it? What other mods do you have? More info the better.
Old Apr 8, 2011 | 06:56 AM
96TransAmboosted's Avatar
Dead cam? so whats that mean the car wont start
Old Apr 8, 2011 | 10:42 AM
Big Al's Avatar
Number one ate both lobes, killed both LS7 lifters. Car was running fine, just had a noise under the valve cover and I went looking. So I need to pull the cam and start looking for it's replacement.
Chased down the cam, it's a Schneider.
Car has all the normal hot rod stuff. Long tube headers, 42 pound injectors, BBK throttle, intake is opened up, ports matched to the heads, big fuel pump. Also has a TH400 and S-60 w/4.30 gears.
It's sick ignition wise too. Has a miss I've been chasing. Was under the hood playing with the ICM when I decided to find the noise. Now I get to look at the Optispark too.
It ran 12.66 @ 107 last Saturday here in Tucson. Miss, flat cam and all.
Al
Old Apr 8, 2011 | 07:39 PM
Big Al's Avatar
Someone pointed me to this cam:
http://www.compcams.com/Company/CC/c...?csid=196&sb=2
Any idea why it says not for LT1 or LT4? Is it a decent cam for my car?
Al
Old Apr 9, 2011 | 11:28 AM
RamAir95TA's Avatar
Al
The 503 is a great cam.
And the LT4 is an LT1, just with a few specific parts. Read: http://www.grandsportregistry.com/lt1vslt4.htm
Old Apr 9, 2011 | 12:15 PM
lt1-xjs's Avatar
Al
The correct part number is 07-503-8 for the LT1, great cam.
Old Apr 9, 2011 | 02:15 PM
greenZ96's Avatar
Im plenty happy with my 503
Old Apr 9, 2011 | 04:12 PM
Puck's Avatar
If you enjoyed the original cam listed, then you will find the 503 WAY too small. If you thought it was a bit unruly, then the 503 may be more tolerable.
Old Apr 9, 2011 | 04:34 PM
Big Al's Avatar
Anybody running one of these?
http://www.compcams.com/Company/CC/c...csid=1103&sb=0
Close to what's in mine now.
Al
Old Apr 9, 2011 | 04:54 PM
Lawhead's Avatar
Thats the 306 there are LOADS of people running that cam there seems to be a 50/50 on people for and people against running it on stock heads
Old Apr 10, 2011 | 04:56 PM
Big Al's Avatar
Here are some pictures of the cam. I think it's a reground stocker. A lot of metal is somewhere
http://s1137.photobucket.com/albums/...t=100_1320.jpg
http://s1137.photobucket.com/albums/...t=100_1319.jpg
http://s1137.photobucket.com/albums/...t=100_1321.jpg
Al
Old Apr 10, 2011 | 06:35 PM
AChotrod's Avatar
yep that cam is dead lol.
Old Apr 10, 2011 | 06:58 PM
Puck's Avatar
Lol damn.
Old Apr 10, 2011 | 07:05 PM
trilkb's Avatar
dude thats one of the best pics ive ever seen.
Props to that thing running 12.66 @ 107 like that! Damn strong runner! I would expect 13's from the cam specs and the wiped lobe!
Old Apr 11, 2011 | 01:43 PM
Big Al's Avatar
Comp Cams recommended a cam for my car. It's a custom grind.
They suggest using a part number 07-000-8 with a grind number
3017/3038HR111+4. "This is a custom grind camshaft and will take 3-5 business
days to complete. I have provided the specs below."
Duration @ .050 236/242
Lift w/1.5 rockers .543/.540
LSA 111 degrees
Not far off the old cam.
Any comments? Also asked if they could do a flat tappet mechanical cam as I'm worried about metal from the old cam, they say no. Did a google search and found people that have done it?
Al
Old Apr 11, 2011 | 01:45 PM
RamAir95TA's Avatar
Why on earth would you want a flat tappet cam? That's crazy talk!
Old Apr 11, 2011 | 02:21 PM
Big Al's Avatar
As I said, I'm worried about metal in the engine. Flat tappet cams are not so sensitive to debris. It was just a thought to avoid more cam problems.
I'm going to pull the engine and look through it but am not planning on pulling it all apart and having it cleaned. More or less I want to see if this crap made it through the oil system and wrecked the bearings.
I don't know where this will all end up but I'm very tempted to toss a regular "old school" small block in and just forget this LT1. I found some small distributors that might fit under the cowl. Not a pleasant thought to have to pull the engine to get the distributor or intake off
Al
Old Apr 11, 2011 | 06:11 PM
why would you need to pull the motor to get the intake and dis off? lol you can do both in car
Old May 5, 2011 | 11:46 AM
Big Al's Avatar
Was looking at things yesterday and found the reason for the "killed" cam. The plate that holds the little "dog bone" part that keeps the lifter from turning has a bent finger. So the lifters must have come out of the holder and turned and that's what killed the cam. Question is why? All I can guess is somehow one of the lifters "lifted" the plate. Can't see any other way the finger would have bent. At least now I know why it only damaged one cylinder.
Al 95 Z28
