Cranksaft and pistons
I don't see why that assembly wouldn't work though. Just make sure you balance it correctly. The difference is most likely in the flexplate and balancer
What is the minimum piston to deck height that I can have? I know optimal would be about .017"ish to help with quench but would it be better to get a shorter piston and mill the deck to proper height or a 0.00" piston to deck height?
Is the front of the crank different on a LT1?
Al
Uploaded with ImageShack.us
No need to weld anything. If your going with a 4.00" then maybe.
Here is my 3.875 in a vette block that's in the car right now.
http://img266.imageshack.us/i/dsc04550x.jpg/
If you want some .030 Wiseco forged pistons I have a set of those for sale.
https://ls1tech.com/forums/parts-cla...1-125-pin.html
exactly......the wsb bolt i run is stronger yet smaller than the L19........prob why i didn't have to clearance my pan rails.....also like i said mine is a billet I-beam.....its a smaller lighter rod..........but as fek said theres no reason you should have to weld..........
The rails and the cam side have been hogged out a bit much, I might get away with a 4" crank, but it would definitely be a half fill if I was going to do it.
Edit: This is more than what you will need for a 3.875" crank, we were just having fun with the mill.
Extra clearance the cam side.
Well, I'm not saying you should go with Eagle on the crank but this is what my setup is. I wouldn't build a shortblock if it wasn't a forged crank and pistons. I run H-beams cause I don't need anything stronger. Oliver rods are awesome, but the price isn't.
The Eagle part number I have is 12113
435338756000 - 4340 3.8750" Crank (Ohio crank can get you a better price)
CRS6000B3D2000 - 6.000" H-Beam (This is their pn with ARP2000 bolts, the cheaper rods come with ARP 8740 rod bolts, don't mess with the L19s either)
Mahle forged 4032 -5.0cc 1.062 Pin height (Decide on the heads and what you are going to want out of the motor.)
If you go with the bearing from them make sure they don't send you that "king" ****, specify Clevite CB663H rod bearings and MS909H Mains.
Also I will definitely be going forged on crank and pistons.
If you don't mind me asking how much did you spend on the whole bottom end balanced and everything?
This is the prices you are trying to beat.
From eagle
$1781.25 for the rotating assembly (12113)
$665.33 Crankshaft (435338756000)
$540.00 H-beams w/ ARP2000s (CRS6000B3D2000)
$575ish Mahle forged
Or you could buy my pistions and make a 388, that would require less machining and you would be running a 3.8 crank and 6" rods.
Here is what my 396
I figured I would have to call them. I am just trying to figure up how much I need to save up to fund my rebuild. And if I am going with another crank I might as well get a big *** one!
Thanks for all the help guys!
