LT1 out the top
Old Apr 11, 2011 | 12:20 AM
MichaelWade's Avatar
Default LT1 out the top
So I have my intake manifold off and the valve covers, I was wondering, when I take the engine out the top where is it best to attach the cherry picker to? Intake mani bolts or just take the heads off and chain it right to the block.
Old Apr 11, 2011 | 12:48 AM
henry172's Avatar
I hooked one set of chains to the water pump bolts and one set the heads where the intake bolts up. It will be easy to pull the block and get to the trans bolts if the heads are off.
Old Apr 11, 2011 | 12:55 AM
MattSapp95_T/A's Avatar
I put a motor in from the top today.. It was an LS motor but same difference...
I used the front Bolt on the passenger side head and the rear bolt on the driver side head worked out great... I had the motor in within 45mins....
Matt
Old Apr 11, 2011 | 09:39 AM
James Montigny's Avatar
You don't have to take the intake off.
Happy Hooker FTW!
Old Apr 11, 2011 | 10:53 AM
confuzzled's Avatar
Do they sell the happy hooker still for our cars? i usually do the one bolt on each head and pull, done that 5-6 times and getting ready to do it agian this week.
Old Apr 11, 2011 | 11:00 AM
LT1/LS1/TPI, it's the same tool. If you want to come out the top, this is the way to do it.
http://cgi.ebay.com/ebaymotors/TPI-L...motiveQ5fTools
Old Apr 11, 2011 | 11:07 AM
Verz's Avatar
+ another for the happy hooker being the way to go
Old Apr 11, 2011 | 12:27 PM
confuzzled's Avatar
Damn i should jump on that!
Old Apr 11, 2011 | 03:29 PM
jaycenk's Avatar
In and out the top with all four wheels on the ground and hood still on and hood struts still conected.
Happy Hooker for the win.
Old Apr 11, 2011 | 04:42 PM
camar0corey's Avatar
My only issue coming out the top is I don't think my picker is long enough, I always end up taking my front bumper off.
Old Apr 11, 2011 | 07:48 PM
jaycenk's Avatar
If you look at my pic you will see there is an extra hole. Measured the distance between the stock one's on the lift (1000 split between them) and then halfed it. Then messured that distance from the last hole and drilled a new one. So I'm down to about 500lbs lifting cap. but it's a long block with intake at that point but I only use it like that on flat ground since I did not extend the wheels out. Still has me on edge but there is plenty of steel still left in the main boom before it gets to the end and it seems to do it no problem. It leaves me with about 1 to 2 inches before touching the front bumper.
Old Apr 11, 2011 | 09:48 PM
guppymech's Avatar
With the Happy Hooker doesn't it make you nervous with all that weight hanging on the 4 fuel rail bolts?
Old Apr 11, 2011 | 11:16 PM
BOLO's Avatar
Yeah, makes you think twice, but TPIS, who designed it, have been using it several years this way with no issue whatsoever... I called them the other day about this concern.
Old Apr 12, 2011 | 04:33 PM
confuzzled's Avatar
It's kinda a toss up really, using those 4 small bolts or just two on the heads.. Both pretty scary if you ask me, but they both get the job done nicely.
Old Apr 12, 2011 | 06:06 PM
96TransAmboosted's Avatar
As long as the bolts are tight then whats the concern with the fuel rail area, it uses 8 bolts to secure it into place
Old Apr 16, 2011 | 04:41 PM
tricked94camaro's Avatar
my thoughts exactly. not only that but the intake is aluminum. i'd probably never do that!
Old Apr 17, 2011 | 01:39 AM
jaycenk's Avatar
I have never had a creak, crack or any noise from that thing while lifting. I have lifted motors with this happy hooker 15 times and never had a problem. No wearing of the threads in the intake or anything. I was worried about using it the first time but since then not so much. I have never seen a thread about someone loosing an engine because of it.
Old Apr 18, 2011 | 11:12 PM
good to know but i go from under anyways
