What I've been up to this winter
Old 05-07-2011, 11:48 AM
  #41
Camaroking1996's Avatar
Why do you have a ported intake but only running a 52mm throttle body?
Old 05-07-2011, 02:51 PM
  #42
green96ta's Avatar
Because a 52mm is more than enough to supply my combo. I have no need for a 58.
Got the harness mocked up and loomed what I could with the harness out of the car. I have replaced 90 percent of the engine harness. Cause im just picky like that. Will have pics up later of some other stuff im going to accomplish later today.
Old 05-08-2011, 10:41 PM
  #43
green96ta's Avatar
I got everything that was mocked up removed and cleaned, then re-installed. heres a couple pics of most of what I got done...
Old 05-25-2011, 10:09 PM
  #44
green96ta's Avatar
Default Finally
Here is another update. still been super busy with work, but ive been able to get a little done.
Old 06-26-2011, 03:22 PM
  #45
green96ta's Avatar
well here is an update. Ive been ***** to the walls trying to get this thing done.....
http://www.youtube.com/watch?v=PW-rAQt1PrI
Old 06-26-2011, 04:39 PM
  #46
95mysticta's Avatar
Link doesnt work.
Old 06-26-2011, 05:31 PM
  #47
green96ta's Avatar
link fixed
Old 06-29-2011, 11:01 PM
  #48
green96ta's Avatar
Default hmm
Well its up and running, but not right... here is the thread over in the tuning forum. maybe you guys can add some insight to what the hell is going on. Im ready to drive this thing.
https://ls1tech.com/forums/pcm-diagn...l#post15099324
Old 06-30-2011, 12:26 AM
  #49
OlMastaScrilla's Avatar
Kind of a random question but how do you like those arp locks. I got some regular comp cam ones but i like that locking feature. Do you think its worth it to just spring the extra cash? its a cc306 car also. Thanks!
Old 07-01-2011, 01:57 AM
  #50
T/ALT1's Avatar
That combo should run really well. I ran a real similar combo back 2003 for quite a few years and it ran awesome for what it was, 355" with forged pistons, LE ported stock castings, CC306 cam, stock lifters, Crane Golds, Pacesetters, full exhaust with cutout, 3600Vig converter, 26x11.5's on motor,best pass 11.20@121mph. Then when I sprayed 150 n20, the car ran- 10.30@130mph,on 175HP- 10.17@133mph,on 325/50/15"M/T with 3.42's in the 10bolt! Then i swapped to a homebuilt 8.8" that worked well.
Old 07-02-2011, 10:42 AM
  #51
green96ta's Avatar
I love the arp locks, worth EVERY PENNY. The best on the market as far as im concerned.
This is what im hoping for. My heads arent LE ported but they are 200cc cnc heads with 2.0 and 1.56 valves. I built my 10 bolt all except for axles. Your times are right where I want to be, so hopefully my car will run as well as yours did. How high were you spinning that motor? Were you using stock rods with arp bolts too?
Quick Reply: What I've been up to this winter
