How many seals do I need?
Here is what I was referencing for the O rings on the water pump
http://shbox.com/ci/water_pump.jpg
It's for a 95, not sure if it's the same for me. They have two O rings that seal the metal coupler.
As far as what you have to do to replace the seals, if you haven't seen anything about installing the waterpump shaft seal already then you will need to be very careful when installing it. It is much easier to install it using a tool to help keep the seal from folding up under itself or tearing and leaking oil. Most people use either a socket or pen cap or part of a pen body to help install the water pump shaft seal. For the socket method I believe the best socket to use is a 1/4" drive deepwell 1/2" socket. You apply a thin layer of oil on the seals inner and outer lips and put it onto the socket making sure the inner seal lip is curved inward and facing the end you would put on a bolt and the outer is curved out and facing the end you would put on the socket wrench.
Then put the socket end (the part you would put on a bolt) over the splined part of the water pump shaft and slide the seal into place being very careful not to damage the inner seal lip or roll it under itself. Even with the socket this can still be hard to do.
I took these photos and included them here to make it easier to understand the socket method but I didn't fully install the seal yet. The final step if you can get it over the water pump shaft without damaging it would be to tap the seal in using a 1/2" drive 15/16" socket until it is fully seated.
Personally I find that the socket method is harder than using the pen body tool method and one fairly detailed thread showing a tool that a guy made with part of a pen is:
https://www.impalasuperstore.com/nai...TOPIC_ID=30984
another thread that shows a tool someone made:
https://ls1tech.com/forums/non-lsx-p...eal-tools.html
Hope that helps.
No worries about redundancies, I'll probably still mess it up haha
