corvette servo
Old Apr 21, 2011 | 06:28 PM
93z28ltone's Avatar
Default corvette servo
Is it worth it?
Old Apr 21, 2011 | 06:33 PM
sjsingle1's Avatar
its a cheap mod.........go for it
Old Apr 21, 2011 | 06:42 PM
93z28ltone's Avatar
Well I'm getting my Trans rebuilt for the second time in 3 months. The pin broke in the servo so I'm having to change anyways so time for a upgrade.
Old Apr 21, 2011 | 06:50 PM
96capricemgr's Avatar
Far as I know all the LT1 cars got them stock. I know even grandma's Roadmaster did.
Old Apr 21, 2011 | 06:53 PM
joshh123's Avatar
+1.. a billet servo would be an upgrade, all v8's got the corvette servo.
Old Apr 21, 2011 | 06:54 PM
lt1-xjs's Avatar
Originally Posted by 93z28ltone
Is it worth it?
Z/28's came with the Corvette servo. The Transgo kit came with the same one that was in my car.
Old Apr 21, 2011 | 07:10 PM
Many people are too quick to jump on the billet bandwagon. The tranny in my car is over 7 years old with a Vette Servo, look at the signature.
Far as all V8s not necessarily true. The 4.3l L99 V8 that was the base engine in the Caprice did not always come with the Vette servo behind it. For those not familiar it was a 200hp destroked small bore version of the LT1 used in the Caprice sedan as the base engine 94-96. Of course GM reused that "name" as they do so many others. I would rather have a new L99 than the old one.
Old Apr 21, 2011 | 08:31 PM
96TransAmboosted's Avatar
I agree that all Vettes and f cars All came with the same servo. If you want to upgrade to a better one that has 34% more holding then a billet servo is the way to go. Check out http://www.4l60-e.com/ they have great parts that i used in my tranny. I have had this tranny on 4 engines without any issues ever. Deeper pan and a tranny cooler will help out a ton for life and protection as well.
Old Apr 21, 2011 | 08:36 PM
93z28ltone's Avatar
Trans cooler is going on it when I get it back and were can I get a deeper pan and what's the price for one.
Old Apr 22, 2011 | 07:42 AM
price is anywhere from 100 300 depending on brand ect, I would get a deeper pan that hold more and is aluminum. There are many choices i would stay away from chrome plated they leak very bad.
Old Apr 22, 2011 | 08:21 AM
James Montigny's Avatar
If you want to shift firmer, get a shift kit. (Transgo or otherwise)
Old Apr 22, 2011 | 01:19 PM
93z28ltone's Avatar
It already has a shift kit from the first rebuild
Old Apr 22, 2011 | 01:48 PM
quik95lt1's Avatar
i run all billet servos in mine with tool steel pins........been alive for four years has over 200 passes on it plus street driving and its still going strong......see sig for what its doing
Old Apr 22, 2011 | 02:32 PM
tricked94camaro's Avatar
somebody explain what a servo is? im a noob at trannys.
Old Apr 22, 2011 | 04:35 PM
http://www.4l60-e.com/HPIM1200.JPG
thats a pic of a servo, When you add more pressure you get a firmer shift (less slippage) there are many different ones that have different apply pressure differences ect 18% 24 34 ect. more apply area the firmer the shifts.
This particular servo is used to apply the band to stop the drum for the 1-2 shift.
I am sure someone can explain it better in broader terms, but that is what this particular one does.
It should also be stated that the links 96transamboosted keeps referencing is a BAD place to buy a tranny from, maybe they sell some decent parts but they can not build a tranny well.
I would also question how long and how much power their parts have held up to.
I have a 7.5yo tranny from another vendor and when you look at my sig, you know I am hammering it with some power.
Old Apr 22, 2011 | 09:58 PM
93z28ltone's Avatar
So I get my car back and come to find out its a 700r4 but not the original Trans that came in the car it the square plug Trans were my car has the round plug for torque converter lock up anyone know were I can get any info on wiring the square 4 wire into my car
Old Apr 23, 2011 | 10:44 PM
thanks for the info. trannys arent something i'd mess with though!
