Man can I please buy a break for a grand????
Hope your daughter is OK!
Your post got me thinking about when I put my car back together last year, and I, too, had a hose clamp slip off, and blow some coolant all over the place, while on my first test drive. I found out at the first corner, when the power steering acted fnny, due to coolant on the pump's pulley....
I've always used the worm drive hose clamps, but I recently installed a set of silicone rubber radiator/heater hoses on my Corvette, and I tried the Gates "shrink clamps". You slip them in place, then use a heat gun to shrink them in place, much like shrink tubing in electronics applications. They're kind of cool, but the down side is that they're a "one time" deal.
The clamp was probably broken or out of place on install if it blew off the first time you got on it. I wouldn't worry about it too much. Hopefully your kid is better soon. Cars can be replaced, people can't.
That sounds like not only a PITA but a waste of money for one time only use. worm gears work perfect and maybe they were over tighten witch happens alot, once there over tight then the clamp can fail at anytime. if my car was a show car only then maybe those clamps would work out and be cool but if you work on your car and ect then a 1 time use clamp is a waste and most likly cost more
My Corvette, however, is a different story. The car is now 10 years old, and this is the first time a hose has ever been touched....and if things go as planned, it'll be at least another 10 before those hoses get touched again. In that application, they make sense....PLUS, they won't cut into the silicone hose, and furthermore, eliminate a lot of the potential "ouch" points that the OE spring metal clamps provide.
Jay now it makes sence, the silicon hoses are more prone to clamps failing dues to how easy the pipe and clamp slide on them, very easy to strip or break a worm gear clamp on those hoses and even easier for the clamp to slide off.
