Man can I please buy a break for a grand????
So.... got the thing back together in the car and ran it up to full temp several times. Topped off fluids, fix a leaking TB gasket and got the idle dead nutz on with good TPS voltage and IAC. Took it out for the first test drive and drove it normal for a while and then picked up the pace a bit to make sure it was running right. Felt great, better then before when the intake gaskets where leaking and I didn't know it. came around a corner and laid into it in second gear, it pulled real hard and then all of a sudden rear tires light up like Christmas. I thought the trans was giving me **** again and slipped or something. I looked out the back mirror and at the gages real quick and didn't see anything unusual. Figured I would turn around and head home and try and figure out what the hell that was, I wanted to check the trans fluid level again and make sure it was ok but as I turned around I noticed the temp had spiked to 210 from the usual 175/180 range. I started to make my way home and I was on a road with no shoulder and no place to stop when I noticed that the temp was now up to 225. got to a place to pull off and shut it down as quick as I could, total time was about 4 min. Shut it down and got out and then noticed a small amount of steam. Looked under the hood and one of the hose clamps failed on the smaller hose that goes to the bottom driver side of the radiator but at the water pump. She had no coolant and odd enough it never steamed a tad when I looked in the rear view. Coolant had dumped all over the rear wheels and caused them to spin and loose traction. I have no idea how quick the coolant came out but the hose was dragging on the ground when I looked so my guess is very fast. I have never had so many problems with a car, a boat, a house as I have had with this ******* car. I swear it is cursed. I inspected all of my work form going through and fixing this engine and putting it back in about 10 times over the past week trying to make sure everything was right and now this.
What do you guys think? Am I going to have problems with this engine again? Even though the temp gauge showed a top temp of 230 there is no way that thing had water in the heads. I walked home and got the wife and drove down with tons of water and fitted a new clamp on the hose and reinstalled it then refilled the radiator about 45min later and finally got the thing bled. It ran at 175 again for the remaining 2 miles home with no surges or spikes. I got it home and topped it off and it was still running nice and cool. No signs of water in the oil or leaks out the side of the heads. Seems to be holding pressure just fine. I will have to wait until Sunday to do a full fill and take it for a run again.
Yea I know but the head and the radiator where bone dry so I am not putting to much stock in the actual temp it reached since the sensor can't actually read a temp if it's not contacting water. Heater was cold when I checked it during the last min of driving.
I would say if the engine was not smoking heavy and it did not reach the red zone you should be ok. It sounds to me like the car has you scared from all the issue you have had and your not thinking clear. We all get excited and in a little bite of a hurry when were close to getting done or starting something new. I would go over everything once more just to make 100% sure all is good. Replace the old clamps with new worm gears. let the car have a few heat cycles in the drive way and recheck bolts after cool down. check the oil,water,tranny before start up during run time and after cool down everytime untill everything is perfect. this alone could prevent alot of issues. But as i have said to you before you are welcome to come over to my shop/house whenever you would like and i could help you for free. Im sure all is good. as for IF you WILL/NOT have issues well i dont have my Crystal ball so i could not say. but good luck to you
I love me some lt1's, but its always the something with the damn things. Walk away from it for a couple days, then get back after it. Atleast thats what I did to keep me from driving the ****** off a cliff lol.
I agree with everyone else that you shut it off in time... shouldnt have any engine problems.
But yeah There shouldn't be an issue at 230 I think half of these temp gauges are **** anyways in these things I caught my gauge at the red zone a few times and never did anything to my heads my head gaskets looked as good as new when I tore the motor apart. Button everything up fill her up with fluids and LET IT RIP!!!
you mean cap leadfoot. cap relives the pressure but only so much over a period of time since the vent is failey small but I found the clamp on the side of the road today and it flat out failed (I'll post pics sometime this week) so if I replace it that much will be fine and not happen again. Still not sure about the engine as I had no intrest in working on it today. I'll F with it monday. My main concern is that if the head gasket adds pressure from the cyliders to the cooling system but I don't think thats the case as the plugs are clean and I found the clamp.
when you say fail.... was it a worm gear that had a broken slot or a factory clamp that broke? would like to see the failed componet.
Also a thermo will make and engine to hot or cold but not cause added pressure.
It was a factory clamp that failed and that’s all I use I don't usually use worm style clamps but it will be getting 2 worms for the time being since I don't have any other clamps. I looked the clamp again and cleaned all the mud off of it and it's not from my car. I went out and looked again but there are tidal water ways on either side of a narrow road where this happened. The one I found had actually been there for a while and is rusted on the bottom and mine was not rusted at all. It was a wire compression clamp with one of the wires broken I found and I remember the one missing on this car is a steal band compression clamp. I may never find it but it was not on the hose even though I took a pic of the car 4 days ago before this happened and it was on there and the hose and clamp were all the way on the barb of the water pump. Duno Just gona refill it when I get a chance. Was going to do it today but my Daughter came down with strep and gave me a huge scare today because she was spitting up blood this morning. She has bad scoliosis we found out a couple of weeks ago and I feared the worst (punctured lung/collapsed lung) but figured it was something related to the sore throat she has had all weekend. May not get to the car until she is better. We shall see. Be a ruff month to say the least.
