Fuel Lines and regulator on VIC E??
Old Apr 30, 2011 | 11:14 AM
AChotrod's Avatar
Default Fuel Lines and regulator on VIC E??
Just trying to get Ideas on how to run the regulator and fuel lines on my Vic E manifold. Pics would be great!
Old Apr 30, 2011 | 01:18 PM
Speed Density's Avatar
hashtagBMW
2 in the front, 2 out the back into a Y, Y to the regulator and back.
Old Apr 30, 2011 | 01:45 PM
AChotrod's Avatar
Got any pics of how you set it up? Ive also seen people do a cross over kinda like the factory set up that looks much cleaner
Old Apr 30, 2011 | 03:07 PM
hashtagBMW
IMO if you have -AN rails you should feed them individualy.
Here:
Best I have, two -8 feeds, -8 off the rail to a Y, Y singles to a regulator and home to the tank.
Old Apr 30, 2011 | 04:35 PM
Wicked94Z's Avatar
run dual feeds up front from a Y, then run each rail into the regulator individually, then return out the bottom. I use an A1000-6 mounted to the firewall. -6 out the back of the rails into a 90* -6 end into the regulator sides. Then run a 90* -8 off the bottom and routed the return back to the top of the tank with a -8 90* bulkhead. No pics right now, car is at the paint shop.
Old Apr 30, 2011 | 04:50 PM
AChotrod's Avatar
Damn having a hard time picturing how to do this. Also wondering if the 860 elbow is the only one that will fit with a stock hood?
Old May 1, 2011 | 09:16 AM
Ray@Nitrous Outlet
Guest
Posts: n/a
best pic I have
Old May 1, 2011 | 12:31 PM
AChotrod's Avatar
Thanks Ray! Thats basicaly what Im going to do. Also show me the 860 elbow fits with a stock WS6 hood
