ARE YOU KIDDING ME??!! Broken Camshaft?!
#41
The broken section of the cam couldn't have moved forward-the rest of the cam is there. AND the pump drive gear was still meshed and holding the cam from moving fore/aft. The lifters stayed on the lobes.
Regardless, the heads/valves are good. I'd still pop out the valves and have a good measure of them. Sometimes the bend can't be seen by eye.
#42
Guys... think about something for a minute. When the cam broke the valve springs were trying like hell to close the valves with almost no resistance from the cam... they could have easily caused the small piece of the cam to spin to a point where NONE of the valves being controlled by that piece of the cam were on the nose of the lobe... It followed the path of least resistance and rotated that part othe cam so that those valves were closed, and/or barely open. It would be pretty bizzarre for them to be hung wide open, it goes against physics. The only cause for that would have been if that piece of the cam got bound up / seized at the perfect position to overcome the spring pressure and hang the valves open.
If the valve springs can control the valve at 7000 RPMS, don't you think they can react faster than the piston moving in the bore at IDLE. Assuming a 700 RPM idle setting, the piston would have only been moving at 406 FPM...
#43
In keeping an open mind about this, I suppose this is possible. Given the fact that there was no damage, and often the simplest answer is the often best answer, this is probably what happened.
#44
In the begining you said you re started it after losing oil pressure? I would be very worried of more damage other than the broken cam.Did you pull a main cap?rod cap? I would pull number 1 rod and main caps.Cam bearings have to be shot.Have you rolled the pushrods also?
#46
wow, really???
Thanks for that awesome and truly helpful advice.
Did it ever occur to you that I didn't WANT to do better than 411 RWHP?? Did it ever occur to you that my GOAL when I did this build was 375 RWHP and I exceeded it? Or that MAYBE my funds are kindof limited and completely rebuilding the block is NOT feesable for me??
It's not ALWAYS about the horsepower. This is a daily driven street car that does EXACTLY what I want it to do, and feels/sounds exactly how I want it to! I dont WANT to increase the HP right now.
gjohnsonws6 - Yes we restarted it for about 3 seconds to diagnose the problem and make sure it wasnt just a faulty gauge..when we heard lifter chatter and no constant knock we shut it back off and it was never restarted. The cam bearings that I could see were fine because the front 4 journals of the cam remained in place and operational, so the only one I am questioning is the rear bearing. I will take a look at it next time I am working on the engine and see what it looks like.
I have completely disassembled the engine as far as I can without ripping the guts out. pushrods were straight and had no issues. I flipped the block over and pulled the oil pan off and turned the crank multiple times to inspect the internals and there were no issues, no noises, no binding, no visible damage, no metal shavings in the oil, the pan or the pick-up screen, nothing.
#48
My advice for what it's worth. Pull the engine, don't even think about not checking out the bottom end. Check the valves. Tops of the rear pistons will have marks if the valves hit. I would have the heads vacuum checked even if there are no marks on the pistons. Drive or push the broken cam out the back. Replace the cam bearings. If the crank saw grit the rear main will have scratches in the bearings. If it does so will the rest. My feeling is running the engine for a few seconds without oil probably didn't hurt anything, but I would look. You admitted to starting it a number of times with no oil pressure. That's why I would look.
From the pictures it looks like the cam wasn't cracked before it broke. There is a good chance metal didn't go through the oil pump as the pump stopped turning when the cam snapped. But I would take a peak just to be safe. I would not be surprised to find a problem in the rear cam bearing, so be easy with it when pushing the broken cam out and examine it carefully.
Al 95 Z28
Al 95 Z28
#49
#50
Yes actually it clearly looks like it was cracked before it broke...
I don't know why its so hard to grasp he said he HAS been into the engine, HAS pulled the heads and everything is fine.
#51
lol great to hear the heads seem ok. Sucks that these things always happen when the funds are low Right? lol check that rear cam bearing and the one in front real good and if your up to it while you wait for Comp pull the front main bearing cap and front rod cap. Those should show all you need to know if there was any oil starvation damage problems to the bearings. If it's stock rods and bolts Shbox.com has the torque specs as well as for the mains. Just use a good torque wrench.
#52
I will. I have a lot of time to wait for Comp, so I will be doing quite a bit of preventative maintenance as well as repair work. I am not going to risk messing the motor up later HOWEVER I am not going to do unnecessary work or fix something that ain't broke if I don't have to.
My plans at THIS moment as far as replacement are:
Replace Cam (obviously)
New Oil Pump and Oil Pump Drive
New Oil Pick-up
Pressure Test the heads
New Oil Pressure Sending Unit (cause I made a booboo lmao)
New NGK TR6 Spark Plugs
Repaint Engine Bay
Clean EVERYTHING thoroughly
Check Cam Bearing and replace as needed
Check Rod Bearings
Paint Block
Port Throttle Body Inlets on Intake Manifold to 58mm
and more to come after I go over everything again Tuesday.
New Oil Pick-up
Repaint Engine Bay
Check Rod Bearings
Paint Block
#53
Ok, so some additions to this list. The bearings in here are whatever Jasper put in it and I don't like when I am unsure about something...therefore, here is my plan. I can not afford all new parts, so I am going to tear the entire block apart and inspect everything, but if it is good and unharmed it WILL go back in.
I am going to be putting Clevite "H" Series Bearings on the Rods
Clevite "P" Series Bearings on the Mains
Clevite Aluminum Bearings on the Cam
ARP Rod Bolts
And everything listed above...
This way there is absolutely ZERO uncertainty and I KNOW the limits of my block and when it was refreshed...
ARP Rod Bolts
#54
Yea just inspect each bearing as to what size they are JUST incase Jasper did something odd and used like one over sized rod bearing or some crap lol. Sounds good though. If you have spare time you can always come and paint my engine bay lol. J/k Little bit of a drive from Wyoming
#55
lol, a buddy of mine is gonna do the work for me for a sub I have hahaha, I just gotta buy the paint. He has his own shop.
The bay is going to be sprayed Jet Black just like the exterior, then I have a few more friends that do custom airbrushing, and they are gonna hook me up if I choose to do this, but I am thinking about having a custom red spiderweb airbrushed into the entire engine bay to go with the car's theme, then clearing everything after that...
Thoughts??
Thoughts??
#57
I am getting a deal, and this wont be done before next paycheck because it will take Comp Cams longer than that to figure out what to do then get to it...so I might as well do SOMETHING till then...lol
#58
Ok, results from the week lol, some good...others bad.
Tore the motor COMPLETELY apart today. As I said before, there were NO marks on the pistons and valves/pushrods were perfectly fine. Everything looks GREAT! Bearings were fine, but I am replacing them anyways to be on the safe side. So here is what all I accomplished and/or learned today lol.
Good:
Cleaned EVERYTHING.
Painted the block Black
Ported my intake manifold's TB Inlets for the 58mm TB
Double Checked my valve clearance and lift
Got the cam sent off to Comp Cams
Inspected everything for damage with no NEED to replace anything but Cam Bearings
BAD:
Valve Seals are FUCKED
6 Valve Spring Retainers are different and I didnt catch it on install
Broke my Oil Pressure Sending Unit......that thing is in a HORRIBLE spot lmao
Cam Bearings are FUCKED lmao
The valve seals are messed up because Patriot sent me the wrong seals with their kit and I didnt notice during install, so the springs have been chewing up the seals...easy fix. I am going to have the Valve Guides clearanced for PC Seals and put those on there.
The Retainers, Patriot sent me 10 of one .050's and 6 Standards...so I have some that are slightly off and I just didnt notice it...gonna try and remedy that as well
Productive day...hopefully things will get better now once all my new bearings arrive and my cam...
Good:
Cleaned EVERYTHING.
BAD:
#59
SO: You've listened to every bodies advice given here and gone through the engine to confirm there's no damage, made some changes and improvements and did some performance work to improve the power you're producing.
Great! We're all looking forward to more good news from you!
#60
Looking at the separated ends of the cam, at the 'beach marks', it does appear that the stress fracture grew over time [i.e.: obviously not caused by a catastrophic event]. That being the case if it was a casting flaw, the flaw may have grown due to repeated flex cycles cause by high spring pressures. Other causes of the repetitive stress cycling could have been bearing misalignment, or too much difference in bearing clearances between the three adjoining bearings. It would seem that a loose clearance in one of the three bearings would reveal as low oil pressure, but low oil pressure may have been masked by high viscosity oil or a high pressure oil pump. With the motor out, you have the opportunity to at least align bore the cam bearing journals as a preventative or corrective measure.
