ignition control module
Old May 10, 2011 | 11:47 PM
unleashedperformance's Avatar
Default ignition control module
ok i have a lt1 in a s10, it keeps blowing the icm. i have replaced it 4 times. i noticed that when i had the belt off and the alternator wasnt turning it was would run fine and never have a problem. but when i put the belt on and the alternator makes juice the icm only last for about 1 min. can anybody help me. this is starting to cause havoc.
thanks in advance.
Old May 11, 2011 | 06:45 AM
shbox's Avatar
Is your alternator overcharging? Have you monitored voltage? Have you checked wiring and grounds?
Old May 11, 2011 | 05:38 PM
it wont run long enough to get a voltage reading when the alternator is hooked up.yes i have checked the wiring and grounds several time
Old May 11, 2011 | 06:30 PM
Big Al's Avatar
What coil are you using?
Al
Old May 11, 2011 | 06:57 PM
stock ac delco coil, msd optispark, msd wires, ac delco icm,
Old May 11, 2011 | 07:40 PM
Big Al's Avatar
shbox.com has all the wiring diagrams. Unplug the ICM and check the wiring. You should have battery voltage on pin A, pin C should go right to the cylinder head (ground). D goes to the coil and B to the PCM. If the alternator is generating too much voltage you would still have to be dealing with a wiring problem as the battery is not going to just go up in voltage that quick. You do have a decent battery in this right? You not using jumper cables to crank it? Did you check the grounds between the engine and chassis? You could unplug the alternator's sense wire and see what happens. (The thin wire.)
Al
Old May 11, 2011 | 07:43 PM
i have a brand new red top optima the truck ran perfectly fine before i rebuilt the motor. and this is a all of a sudden kinda thing. ill check the wiring right now
Old May 11, 2011 | 10:51 PM
wiring is correct didnt find any bad grounds.
Old May 12, 2011 | 01:07 AM
Big Al's Avatar
Wish you were in Tucson. I'd like to see this one. When the ICM dies what codes are in the PCM? When the ICM quits, exactly what is the result? No spark I'm sure but are the PCM pulses there? Look up the codes 41 and 42 (ICM problems) at least one of those codes kills the fuel, IIRC. I'm still concerned with the grounds. Is the negative battery terminal connected to the block or the chassis? And what year is the engine and PCM?
Al
