305 cc 114lsa
Old May 11, 2011 | 04:25 PM
97TAJT's Avatar
Default 305 cc 114lsa
Any body have a video of a 305 cc with a 114lsa at idle trying to see what it sounds like
Old May 11, 2011 | 04:27 PM
draggin97s10's Avatar
Old May 11, 2011 | 04:32 PM
Camaroking1996's Avatar
Is that even offered?
Old May 11, 2011 | 04:51 PM
Purple Poncho's Avatar
Some idle in the following:
http://www.youtube.com/watch?v=nxxMA_5uD2k
http://www.youtube.com/watch?v=1u8vd...eature=related
Old May 11, 2011 | 05:04 PM
97TAJT's Avatar
yea bought a 305 cc and its a 114 lsa not the 112 just trying to see how big of a difference there is at idle..
Old May 11, 2011 | 05:14 PM
RamAir95TA's Avatar
I hope you have low expectations at the track.
Old May 11, 2011 | 07:03 PM
SS MPSTR's Avatar
This was my first cam in my car. Mild, to say the least, but certainly woke my car up with a few supporting mods. My goals then were to pass CA emissions testing legally, and it did that.
Old May 11, 2011 | 07:23 PM
96capricemgr's Avatar
A decade plus ago everyone mistakenly thought injection needed very wide LSAs, these days most of the fast NA cars are running say 107-110LSA, not the best for emissions but good for power. With a cam as small as the 305 though it should pass emissions on a 112, 114 is going the wrong way.
I didn't watch the videos but I imagine it would sound pretty darn stock and if you raised the idle a little could sound dead stock.
Old May 11, 2011 | 07:28 PM
97TAJT's Avatar
good thing i got it cheap lol gonna sell it
Old May 11, 2011 | 07:34 PM
I don't know much about turbo cam design but I think they like wide LSA. Wonder if it would be a good fit for such a thing?
Old May 11, 2011 | 08:07 PM
1toofastlt1's Avatar
im running this cam in my 383 build. Im going to be running a lot of boost and still need to pass smog. My friend made 614rwhp @ 14psi.
Old May 11, 2011 | 08:25 PM
That is what this is cam is on.
Motor was done in 2001 and had to pass Ontario smog, which is a bitch. Pushed a 3850 lb cast crank (OMG!!) 383ci to 137 mph in the 1/4 mile. For what I knew 10 years ago it has worked out. Made 600rw or so with 10 psi.
No doubt there are better cams now.
Old May 11, 2011 | 08:28 PM
call or email loyd elliot. he will make you a killer boost cam.
Old May 11, 2011 | 09:44 PM
robsquikz28's Avatar
bwhahaahahhaaaa
Old May 11, 2011 | 10:02 PM
mguidry629's Avatar
The cc305 comes off the shelf with a 114LSA. I went with it because it didn't require a stall, gears, etc. It's got 15+ duration over stock and .060" more lift w/1.5RR so of course it will perform better than stock. Are there better cams out there? Sure, but this is a good budget cam that doesn't require $thousands worth of supporting mods. Don't get discouraged by the comments. It's a good reliable sleeper cam that won't give you idle problems. If you wanted an all out agressive cam to make power to 6500 then you should have told me and I wouldn't have recommended you buying it from me. Put it in there with 1.6s and you'll be happy with it. Or sell it and go more agressive. You'll be able to get what you spent out of it, I had several people wanting to buy it.
Here is a burnout video of when it was in my car on a bone stock tune, headers, ory pipe, stock catback and flowmaster muffler. Not much idleing going on but still sounds pretty good imo.
http://youtu.be/ToJ3H0IzdXg
Old May 12, 2011 | 05:26 AM
"doesn't require a stall" is a joke, the stock cam loves a 32-3600 stall.
Old May 12, 2011 | 06:18 AM
STOCKTA's Avatar
I loved my cc305 144lsa cam back in the early 2000's, instant power curve that peaked quick and was fun to daily drive for 6-7 years. I do agree that it really woke up about 3500-4000rpm's and imagine a more modern smallish cam would come on quicker and stay there longer. All in all I still crushed cars with bigger cams because of the total package and quick power band so I loved it regardless if the gm847 and cc306 was my buyers remorse about the cc305.
Old May 12, 2011 | 02:01 PM
WS Sick's Avatar
Over a decade ago I had a cc305 in my LT1 with the 114 (i think it only came in a 114 LS) but it had a nice drumbeat idle. It also trapped in the 112 mph range.(3000 stall, 3.73s, longtubes.) it was fun, but there is much better now.
Old May 13, 2011 | 07:12 AM
97pontta's Avatar
A good example of this: I installed this exact cam (CC305 on a 114LSA) in my car back in 2002 while still running the stock stall. Keeping the stock stall was a HUGE mistake, the car was a dog off the line. I installed an EDGE 3400 stall and went from 13.00@108 1/4 mile times to 12.3@110 just with the stall.
Old May 13, 2011 | 09:11 AM
Z28Roxy's Avatar
Here's a pretty similar one. 218/230, .528/.544, 114 LSA:
http://www.youtube.com/watch?v=yrvv-GfbAng
Car is a 383 though. But it definitely makes a clearly defined lope (horse gallop) in closed loop.
