finally decided to go with nitrous
Old May 11, 2011 | 09:32 PM
Drak03's Avatar
Default finally decided to go with nitrous
Ok so im picking up a nitrous kit on friday for$ 150 from a friend. To me its a really good price for the 10lb bottle, heater, mounting brackets, all the hoses, pressure gauge, and nozzle. And an extra 75 for a walboro 255 fuel pump. What all else would I need? Im going to be getting a purge kit from jegs, I get a discount cause I work there, and I need to find an arm and purge switch
Old May 11, 2011 | 09:33 PM
Drak03's Avatar
Oh I forgot to say its only a 75 shot dry for right now. Working on another engine hopefully will be done by winter, I kinda started *** backwards and need to get the block now lol
Old May 12, 2011 | 08:46 PM
Ray@Nitrous Outlet
Guest
Posts: n/a
the fuel side of your wet kit seems to be missing
but on that note...I would need to know everything part wise you are getting for the dry kit to know if anything is missing.
Old May 12, 2011 | 09:36 PM
96capricemgr's Avatar
A stock LT1 can handle more than 75 worth, a LOT of guys do 125-150. Easy to create a pile of scrap if you do something wrong though.
Old May 12, 2011 | 09:56 PM
Drak03's Avatar
Lol yea the wet side is missing!! Ill get a full list tomorrow. Im just gonna start off with a 75 shot not staying there for long though
Old May 13, 2011 | 12:28 PM
Green3spd's Avatar
I ran a 125 wet Zex kit for about a year. Not A LOT of bottle but pulled head and everything looked great
Old May 13, 2011 | 03:18 PM
Beau@SDPC's Avatar
LS1Tech Sponsor
WOT Switch, RPM Activated Window Switch, and PSI safety switches would be a good idea. This coming from someone who just popped a head gasket on 150 wet kit with no pressure saftey switches
Old May 15, 2011 | 12:33 AM
Drak03's Avatar
Anyone know where I can buy the plate that goes in my cigarette tray that has the arm switch, purge and the other ones. I found it once but compeletly forgot where it was
Old May 15, 2011 | 11:57 AM
AChotrod's Avatar
Nitrous Outlet can hook you up with a killer ashtray switch panel. They also have everything else you might need or need help with. Awesome guys to work with!
Old May 15, 2011 | 07:13 PM
Drak03's Avatar
Awesome, thanks man!
