Pulling Intake
Old May 14, 2011 | 02:19 PM
IronOutlaw's Avatar
Default Pulling Intake
Well I changed the oil in the car last weekend and noticed there was oil all over the transmission bellhousing. That explains why my clutch is slipping so bad.
So now I get to change the clutch and intake gasket in the same weekend. Are there any tricks to doing it or is it gonna suck as bad as I think? I just need to know anything that will make it easier/quicker. I guess while Im in there Im gonna go ahead and change valvecover gaskets and put in a new rear main seal.
Old May 14, 2011 | 02:28 PM
camar0corey's Avatar
Pulling the intake manifold isn't bad. Its pretty straight forward. The Haynes/Chilton says you should loosen and torque the bolts in a certain order, that is about the only thing that seems to earn any attention.
Old May 14, 2011 | 02:35 PM
Big bird55's Avatar
i pulled the intake in about 5 minutes. hardest thing fro me was getting the injectors and rails out.
Old May 14, 2011 | 03:53 PM
trilkb's Avatar
i dunno about 5 minutes but its seriously not that hard. Its just loosening bolts and messing with injector harnesses and some vaccum lines here and there.
If your not a cali car, do the EGR delete if you havent yet. "they" say thats one of the reasons the rear seal fails, it gets excessive heat and breaks down.
As far as the trans goes a good swivel socket, not just a swivel with a socket, but spend the money on an actual swivel socket and get a 24" extension to go with it, that will help get most of the bolts on the bellhousing.
You deffinetly have a full plate, but the intake isnt as bad as your thinking.
Old May 14, 2011 | 03:54 PM
Big bird55's Avatar
it was easy most of the other stuff to the intake was gone so i had little to do to pull it
Old May 14, 2011 | 04:19 PM
Octavarium's Avatar
I am assuming you deleted the emission crap on the intake? That makes the job a helluva lot easier, that is part of the reason I deleted it . The job looks a lot harder than it is with the engine being halfway under the windshield but in reality it is really simple and straight forward.
Old May 14, 2011 | 05:55 PM
Big bird55's Avatar
yep
Old May 14, 2011 | 07:45 PM
IronOutlaw's Avatar
Ive got stock manifolds. Can I delete the EGR and just try to seal off the EGR hose until I can get some headers.
How will the car run with EGR deleted and no tune?
which if funds permit, Ill be buying a set of Longtubes and throwing in when the Tranny is pulled. It would be ALOT of work but everything seems to be easier to work on when the tranny is out.
Old May 14, 2011 | 08:17 PM
trilkb's Avatar
they make kits with 3 block off plates, 2 for the rear of the intake, and one for the stock manifold.
Old May 14, 2011 | 08:35 PM
5_LTR_ETR's Avatar
sorry to threadjack but i bought that kit^^^ and only ended up putting one plate on the back of the intake. what the hell did i miss?lol i assumed the other 2 were for the stock manifolds or something and didnt even bother to check... its bin a few months now and no problems
Old May 14, 2011 | 10:37 PM
jaycenk's Avatar
What does the intake have to do with a slipping clutch???
Old May 14, 2011 | 11:20 PM
chevymec's Avatar
Oil leak from intake= leaking onto/into bellhousing onto clutch.
Old May 14, 2011 | 11:32 PM
casper's6liter's Avatar
i have a 1996 impala will this egr delete kit work for it the car is bone stock
