Shim Gasket Pics
Old May 26, 2011 | 02:25 PM
Dave357LT1's Avatar
Default Shim Gasket Pics
Does anyone that has modded the sbc shim gaskets to work for lt1 heads have and pictures after they trimmed them? I just want to make sure i get it right before i throw them on. Thanks
Old May 26, 2011 | 02:31 PM
quik95lt1's Avatar
which gaskets are you talking about???
Old May 26, 2011 | 02:34 PM
Big Al's Avatar
http://www.summitracing.com/parts/NAL-12553160/
Al 95 Z28
Old May 26, 2011 | 02:39 PM
Dave357LT1's Avatar
Originally Posted by Big Al
No these
http://www.summitracing.com/parts/FEL-1094/
Old May 26, 2011 | 02:42 PM
Dave357LT1's Avatar
I have the TFS 195 Heads. Ive had them milled to 60cc but want to run the this gasket to bump my comp. as much as i can.
Old May 26, 2011 | 04:44 PM
LilJayV10's Avatar
I know victor renz makes a shim gasket too. I used some one my friends 95Z I just built.
Old May 26, 2011 | 04:48 PM
LilJayV10's Avatar
https://ls1tech.com/forums/lt1-lt4-m...1-gaskets.html
Old May 26, 2011 | 04:57 PM
boosted LT1's Avatar
Better review application before you buy!
Fel-Pro Q1094 - Fel-Pro Performance Head Gaskets
Make CHEVROLET
Engine Type V8
Liter 5.7
CID 350
Engine Size 5.7L/350
Beginning Year 1967
Ending Year 1998
Engine Family Chevy small block Gen I
GM Performance 12553160 - GM Performance Composition Head Gaskets
Make CHEVROLET
Engine Type V8
Liter 5.7
CID 350
Beginning Year 1996
Ending Year 1996
Engine Family Chevy small block Gen II (LT-based engines)
Application Notes LT4, engine vin code 5. Designed for use with aluminum heads only.
Calculator Compression Calculator
Old May 26, 2011 | 05:18 PM
Dave357LT1's Avatar
I know people have used those gaskets on lt1's you have to open up the water ports. I was just asking if anyone took pictures or the amount they took out.
Old May 26, 2011 | 05:24 PM
Dave357LT1's Avatar
Here is a link to the thread with people using them so i KNOW they work
http://ltxtech.com/forums/showthread...highlight=shim
Old May 26, 2011 | 06:22 PM
Well hell you read it on line it must be FACT?
The only way to KNOW they work is to have done it! I have learned to be skeptical of internet posts stating parts will work!
I just added a Vortec dizzy to an LT1 if you read about it on the internet there is no problem, BUT in reality there are a few small problems like: the EGR and EGR boss, fuel lines and fuel pressure regulator are all in the way and need to be 'adjusted'.
... I have a 4400 and a 3.90 gear and the stall is streetable 100% but it revs high on the highway.
A few things people will want to know:
What cam do you have? (Which LE)
What is your estimate of CR with the .028” and this gasket?
What are you trying to achieve? DD?
Don't just say maximize CR or power, the better you describe your goals the more likely you are to get replies that help.
Believe it or not some just read a couple articles on line and throw this and that together and end up with high CR small cam huge stall and wonder why they get crap MPG and get beat by stock vehicles.
Welcome and good luck
Old May 26, 2011 | 06:48 PM
Dave357LT1's Avatar
I didnt ask or want to tell what my CR is or will be with this gasket. I asked how much to cut out of the water ports on the gasket. Why do i need to tell you my goals and cam size to know how to mod a gasket? L.E. set me up with my cam for my specific application but i dont see how it is relevant to what i asked. I know that it works because the guys running them have had them for a while and havnt had a problem. And like you said the only way to know how to know it works is by doing it.... so i guess im going to have to do it to know for sure.... i asked a simple damn question that needs a simple answer. I take it this is why people on LTX said dont come over here and ask questions......
Old May 26, 2011 | 07:02 PM
LilJayV10's Avatar
Disregard my post. I misread your original question.
Old May 26, 2011 | 08:13 PM
I didnt ask or want to tell what my CR is or will be with this gasket. I asked how much to cut out of the water ports on the gasket. Why do i need to tell you my goals and cam size to know how to mod a gasket?:
Because most people on this site try to prevent newbies from bastardizing their cars for insignificant returns.
I won't try to explain all the problems this will cause and for <10 RWHP it isn't worth it IMO.
I suggest you go to a parts store and put an LT1 head gasket over a Gen 1 head gasket...
Again good luck
Old May 26, 2011 | 08:25 PM
badass383formula96's Avatar
Wow this thread is full of fail because of nothing but put ignorance. I absolutely love how this site can take a thread that ask a simple basic question and turn it into pure bullshit. We all learn by trial and error, if we don't learn that way then we learn by reading on the internet which is what this site is for. Many people have run shim gasket, me not being one of them but still. Find someone that has and send them a pm it will completely avoid trolls like this thread is full of.
Old May 26, 2011 | 08:31 PM
ScreaminRedZ's Avatar
registered user
I think the problem is that too many people want to make others look/feel stupid instead of just trying to inform people and give the best advice they can.
Old May 26, 2011 | 08:37 PM
Exactly this site used to be pretty decent when i first joined now it went to hell. There's a few decent ppl still around here so im not saying it about everyone.
Old May 26, 2011 | 09:10 PM
Can an old style headgasket be used on an LT1?
Yes
Will you end up with coolant leaks? It is more likely to leak than using the correct gasket, but if ~10 rwhp is worth the added risk then use a gasket as a guide.
10 rwhp isn't a BS number it assumes he gets 2.5% and has 400 and that is HIGH considering the difference of the two gasket thicknesses
A better method to increase his CR is too deck the block or take more off the head.
If you want to say BS address something specific. I agree forums ARE meant to share, and that means to identify and CORRECT what is wrong so others will learn what was incorrectly posted.
If there are significant errors quote so we can all have the right information.
Old May 26, 2011 | 09:25 PM
Dave357LT1's Avatar
Heads are shaved as much as CFM was comfortable doing and the motor is in the car so shaving the deck is out of the question. So at this point im willing to risk doing it. Its not my d/d.
Old May 26, 2011 | 09:55 PM
If you are set on doing it then take the heads off, and use the old gaskets as a guides and remove material SLOWLY. I still suggest you compare cr between .028 and .018
My point was to get YOU to see the difference wasn't worth it.
ie If the engine has 10.2 with .028 and you change it to .018 the compression goes to ~10.5 or cr increases .3 not bs just physics. Then even if you get 4% per point of increased cr that would yield ~1.2 hp per 100 or ~5 rwhp if you have 400 rwhp..
I used
http://www.csgnetwork.com/compcalc.html
Not the greatest bang for the buck and for the $$ there are many more reliable mods to increase performance, but it is your car.
Edit: going from a .040" gasket to a .018 yeilds ~.54 or 8.5 rwhp
