Evap delete
Old Jun 1, 2011 | 01:22 PM
camar0corey's Avatar
Default Evap delete
So I removed the canister. I see three lines? I guess I was expecting to see two, one in, one out to the front. I always here people put a filter on? What does this filter look like or does anyone have a part number? Which line do I put this filter on?
I tried a search, hell if that made anything clearer.
Old Jun 1, 2011 | 02:33 PM
Tampa_97_SS's Avatar
Check post #21 of this thread below:
https://ls1tech.com/forums/drag-raci...-delete-2.html
You place the filter on the hose coming from the tank to the canister; cutting the hose right before the canister and installing the filter at the cut I believe. From what I read, most people just get a standard filter from the parts store that will plug into the line, and secure it with a hose clamp. The filter is supose to stop any debri from getting into your tank. I have not done this myself, but have been reading up on it for the future. The car will throw some codes too; so you may want to have the codes programmed out.
Hope that helps Corey.
Old Jun 1, 2011 | 09:15 PM
Thanks!
