Turbo 383 Build.. AGAIN
#43
Thanks everyone! Ed, I sent you an email.
700rwhp sounds nice.
I ran a 11.1 @ 128 detonating all the way down the track![Bomb](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_bomb.gif)
Not sure on weight. Removed some stuff, but also added a lot. I need to weigh it sometime.
Bingo. The stock lines do not match up at all.
Here is where I'm at now:
![](http://i67.photobucket.com/albums/h290/MWRalls/IMG_2265.jpg)
![](http://i67.photobucket.com/albums/h290/MWRalls/IMG_2266.jpg)
Everything was going good. It was ready to go back in this weekend. That is, until I found out my exhaust cross-over/merge hits the new oil pan. I need to make a new cross-over which is going to delay things for a few weeks I would imagine.
#44
Who built the turbo kit? Looks nice, I still can't make up my mind if I should go ProCharged or single turbo. Each has their positives, but I just can't make up my mind, but then again its a couple years off
Too bad about the cross over pipe, but that type of thing always happens to me. You get something to work, then change it, and then you have to change 3 other things to make it all work together again haha. You still have alot of summer left, thats what my buddies keep telling me
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
#47
Too bad about the cross over pipe, but that type of thing always happens to me. You get something to work, then change it, and then you have to change 3 other things to make it all work together again haha. You still have alot of summer left, thats what my buddies keep telling me![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
It was capable of 10's before if everything would of went smoothly. It's more setup for street driving with minimal weight reduction; but it does an amazing job of keeping traction. A lot of that is due to the 4l60e, 3.00 gear ratio, and fully upgraded rear suspension.
#48
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
#49
The build looks good and I hope it holds up this time. Subscribing for updates.
#51
They are cheap ebay valve covers. It took some work to get them to fit. The bolts that came with them were too short. Mainly because the AFR perimeter bolt holes are recessed to far down in the head. Even then, I could only get 3 out of 4 bolts in because the holes didn't line up perfectly. I ended up drilling the VC bolt hole guides larger to get it to fit. I may change to something else one day. Not a huge fan of tall valve covers.
#52
I decided to continue on and have the shop who will tune my car also fabricate the merge pipe. Tonight I slammed it back in. Tomorrow will be the tedious part of hooking everything up.
![](http://i67.photobucket.com/albums/h290/MWRalls/IMG_2269.jpg)
![](http://i67.photobucket.com/albums/h290/MWRalls/IMG_2270.jpg)
![](http://i67.photobucket.com/albums/h290/MWRalls/IMG_2271.jpg)
![](http://i67.photobucket.com/albums/h290/MWRalls/IMG_2272.jpg)
![](http://i67.photobucket.com/albums/h290/MWRalls/IMG_2273.jpg)
![](http://i67.photobucket.com/albums/h290/MWRalls/IMG_2277.jpg)
![](http://i67.photobucket.com/albums/h290/MWRalls/IMG_2278.jpg)
#54
You and me both....I have a plan bouncing around in the back of my head
Along with my old factory k member all I need is a motor and I'm going to start building my kit
Keep up the good work man, looks stunning
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
#59
Before I just had a vented catch can running off the valve covers. This time I added a crankcase vacuum pump. See it mounted where the alternator was? It took a lot of work to make that happen. The brass fitting you see is for my vacuum gauge to monitor crankcase vacuum. I'm pretty excited to see how well it works.
