Turbo 383 Build.. AGAIN
#63
I ran 15psi before. With the better pistons and AFR heads, I can run more. It depends on how tuning goes. I plan on competing in the LTX Shootout this year so keep an eye out.
Thanks. They are UMI 3-point bolt in subframe connectors.
#65
It's already starting
. Are there any valve covers out there that don't completely suck? I filled it up with oil last night and today I see it leaking at the back of the cover. I'm trying to keep my engine bay oil free this time!
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
#67
I use stockers, but I don't know if you could use them with a vacuum pump. And they don't look the greatest, I'll be changing mine out after I get it up and running again
I can't wait to see some dyno numbers, I priced out a procharger setup the other day and after that sticker shock think I may want to do a turbo setup haha. Overall cost is similar, but the adjust-ability of the turbo setup as well as the "free" power you gain is making me lean the direction again.
Keep up the good work, you can't have a project like this without a few snags along the way, thats at least how it works for me
![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
#68
Probably in 2-3 weeks.
I did use felpro silicone rubber ones with the steel core. It's the valve covers. I tossed them out and got a set of cast aluminum covers. Much more solid than fabricated sheet metal. We will see how these ones work.
Yeh I'm not sure if a turbo or procharger setup is cheaper. I would think turbo is more expensive unless you built the hot parts yourself. The good thing about a procharger kit, is that it's going to fit since mounting holes on the engine don't change from motor to motor. A turbo kit might not fit every car once you start changing things like motor mounts, k-members, oil pans. Hmm sounds familiar lol.
Anyways, I should have it buttoned up this weekend. Then it's off to a shop to get the merge pipe fabricated and tuned. I'm curious to see how much of a difference these AFR's are going to make.
Which gaskets did you use?? I have always had good luck with the blue rubber fel pros. I think you can get them with the metal insert in them so they can't push out when you tighten them down.
#69
Which valve covers did you get? I saw that Jegs has their cast tall covers on sale for $75. I thought about grabbing a set and having a friend of mine powdercoat them in wrinkle black
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
#70
I never could figure out the brand of the valve covers. I bought them from a local speed shop. They were the only ones with a clear underside so I could drill and mount my oil fill cap and AN bung. The polished aluminum matches the engine better too.
One other hiccup presented itself. The welds on my fuel rail for the AN bungs have a few pinholes which leak fuel. That's getting fixed now so it shouldn't slow me down too much.
#71
The car has been running great so far. I finally got it dyno tuned the other day. I'm making a little under 500hp at 12psi on a mustang dyno. I have been having issues with increasing the boost with manual boost controllers. Right now it's running off the gate spring. I've tried two ball and spring type controllers and they both make too much boost even when it's turned all the way down. The lowest they dial down to is like 18psi. Once I get that figured out I will add a safe amount of boost and spray water/meth.
I'm going to take it to the track tomorrow and see how she runs as it sits. I'm curious to see how it compares to my last run of 11.1@128 when it lifted the heads, blew the head gasket, and broke the ring lands. It doesn't feel as fast as before, but it's more efficient. Turbo spools faster and I'm revving past stock shift tables this time. Wish me luck!
#72
Jon
#74
Unfortunately, no. I was heading there and the road to the track was closed. The detour was too much out of the way to be there on time. Plus it rained a little right before so who knows how the track conditions would of been. I'll try again next Friday.
I agree 500hp is pretty low. With 8.5:1 compression, it's asking for more boost.
I was thinking about this today... is there a larger turbo that will fit without modifying the exhaust?
#76
A T76GTS is the biggest that will fit with no hotside modifications.
#78
I was thinking about it more... you made 650rwhp @ 15psi previously on a dynojet right? If so, that probably would have been 575rwhp or so on a mustang dyno. You made ~500rwhp @ 12psi (3psi less) this time around on a mustang dyno, so you may not be too far off. I would push that TC78 to its limits first befoe swapping out.
I will get a picture of the new cross-over for you.
It's a 3" to 4" reducer and it fits fine. However, the first one I bought was too short so the transition was too drastic to fit all the way around the TB. The one on it now is about an inch longer. I can try to figure out what brand I bought if you want.
