LPP y-pipe doesn't fit right
I had the local speed shop put on the second batch LPP long tubes & ORY for me a few days ago.
They said the drivers side header went on easy but the passenger side was a PITA. They also couldn't get the ORY to fit right because the passenger side header points slightly upwards.
Looking under the car, you can clearly see it.
Has anyone encountered the same problem? I'm actually headed for the exhaust shop next Thursday, should I be prepared to have them make a new ORY?
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
![MAD](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_mad.gif)
Thanks for the advice. ![Chug! Chug! Chug!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_chug.gif)
Brand new poly motor mounts.
I doubt anyone cares, but I eventually got it to fit. Took me quite a while to be honest lol. Then I had the exhaust shop make a new I-pipe to connect the cat-back to the ORY. Man, talk about a different sounding car! First WOT = instant boner.
I also had them put a cut out right before the axle.
I'll probably get a soundclip up in a few days. I never found a good video on youtube that shows how a stock LT1 with lt's and a Hooker Aerochamber sounds.
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
![The Patriot !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_patriot.gif)
