96 Z28 (LT1) Overheating
Old 06-17-2011, 07:20 AM
quik95lt1's Avatar
i really dont understand all the air bleeding problems.......ive never once had this issue lol
Old 06-17-2011, 07:25 AM
Wicked94Z's Avatar
oh **** it's a girl!!!!111
Old 06-17-2011, 07:29 AM
3.8blackmaro's Avatar
I would replace that water pump as soon as you can if it is leaking. If you don't you will also be replacing the optispark as well.
Old 06-17-2011, 07:37 AM
quik95lt1's Avatar
why u think there's so many responses to this thread steve
Old 06-17-2011, 08:23 AM
BowtieGirlZ28's Avatar
Nah, I'm really a guy, I'm just pretending to be a girl so I can get more feedback It worked too
Old 06-17-2011, 09:07 AM
Thanks, I will find out more later today...
Old 06-17-2011, 09:43 PM
Okay, got six bolts off the old water pump...I'm assuming the other two holes(on the back) are for alignment? Having a hard time getting the pump out, not a lot of room to pull it forward off the gear thingy. To dark to keep trying, so I will try again tomorrow.
Old 06-17-2011, 11:59 PM
fex77k's Avatar
Yea there is only 6 bolts holding the water pump on, if you have to get more room you can always take out the electric fans.
Old 06-18-2011, 12:18 AM
ZFreie's Avatar
This is what I did, they come out pretty easy and a bunch more room to work.
and not to but quik95lt1 & Wicked94Z thank you for A+ sig. Ill be keeping this one for a while. I got a really good kick out of it.
Old 06-19-2011, 04:38 PM
ummm, i got the old w/p off and the new one on and now it seems im not getting any fire to the engine, it wont start...does that Sound like the optispark
Old 06-19-2011, 06:52 PM
Camaro350Z28's Avatar
That could be.. but did u put it all back together? Did u unplug the opti? Perhaps u didn't put the coil wire back on?
Old 06-19-2011, 07:20 PM
  #32
Yes, I put it back together & put the coil wire back on, Now I will prolly have to take it all out again I wonder if the coil wire is bad, I suppose all the overheating could cause a lot of problems with the wires too....
Old 06-19-2011, 07:23 PM
  #33
I broke this bracket too...oops!!!
Old 06-19-2011, 10:53 PM
  #34
luckily that mount spot dont matter really. so still no fire huh? did you cover the opti with like a plastic bag or anything to prevent water from getting in it while removing pump? did that much spill on it? i wouldnt think it would happen but ive seen worse happen. you might wanna try to let it dry out for a day and try firing tomrorow?
Old 06-20-2011, 06:47 AM
  #35
Wicked94Z's Avatar
hey those are a girl's dirty hands!!
Old 06-20-2011, 08:13 AM
  #36
nah, they are special gloves that make you think they are girls hands The gloves are so convincing that I'm actually in a relationship with my left hand...
Old 06-20-2011, 08:18 AM
  #37
quik95lt1's Avatar
creative lol.............so did you figure this thing out?? make sure the ICM is still plugged in and also the grounds on the front of the cylinder head are still hooked up........check the opti harness and make sure its still plugged in...........if thats all good its possible that you gave the opti a little coolant bath in the process of yanking the pump.........opti's dont like taking baths lol
Old 06-20-2011, 08:22 AM
  #38
i figured the mount thing would be okay so I just put it back on...I didn't have time to fool with the Camaro before work today so I will try when I get off...I hope it starts!!!
Old 06-20-2011, 08:33 AM
  #39
Wicked94Z's Avatar
My optis take baths with me all the time, they like it
Old 06-20-2011, 08:50 AM
  #40
Yeah, I may have given the opti an unwanted bath I will check all the above and see if I can get it started...Thanks for the help
Quick Reply: 96 Z28 (LT1) Overheating
