Anyone using the Meziere HD EWP?
Old 06-27-2011, 06:33 AM
RamAir95TA's Avatar
CSR hands down. Even though you have to SLIGHTLY grind the pump housing for it to fit, no one will ever see it. No fan shroud hacking - it looks like it should be there.
Old 06-27-2011, 08:20 AM
Z28Roxy's Avatar
Even with the HD pump you can't see the fan shroud hacking.
Old 06-27-2011, 08:22 AM
quik95lt1's Avatar
ive got the standard mezierre pump......been on the car since 2001 with no issues at all and it flows plently of water to keep me cool in traffic or even hot lapping........at thats at 14:1+ CR
Old 06-27-2011, 11:25 PM
Wicked94Z's Avatar
If CSR made a ***** pump... I'd buy one since their EWPs are so reliable
Old 06-28-2011, 07:57 AM
quik95lt1's Avatar
sounds like a personal problem lol.......personally all i really need is the EWP lol
Old 06-27-2012, 05:32 PM
TexasNative's Avatar
Originally Posted by gregrob
The meziere pumps I've dealt with were all disappointing junk.
The CSR has worked much better and reliably for us. FWIW
Kickin' up the dust on this old thread but I was looking to see how much shroud cutting was required. I just bought a Meziere HD for my 96 TA because my CSR went out in 725 miles on a brand new $10,000.00 engine and caused me to have to do some major work. Never will buy another CSR pump. Went with the Meziere HD because of nothing but good things from the guys around here that run them.
Old 06-27-2012, 06:39 PM
FAD2BLK93's Avatar
I run the mezier HD, it is pretty long. I have cut a notch in the shroud with a dremmel tool. My radiator is angled back for the Ls1 lid conversion and it pins the fan blade so i would have to slice the blade in half, paper thin. So i just unplugged it, and so far the use of one fan has kept my motor extremely cool. Barely comes up on the guage, im not even sure yet if the thermostat is opening. Lol. I have not had mine long but i like it so far!!!!
Old 06-27-2012, 06:57 PM
n2oblkz's Avatar
Been running a Mezier HD pump for years now.
Old 06-27-2012, 08:16 PM
Village Troll
SS RRR's Avatar
Not much. Best way is to just mount the pump and put the fan shroud up in the general area (unless there are pics). I used a pair of dikes. Made quick work of it. The "hacking" will go completely unnoticed if the shroud is in the stock position.
Originally Posted by SS RRR
Therefore art thou Grumpy Pants Greg spoketh to where thou heedeth thine message. If to which thine message is not heedethed, doom and destruction thou shalt strike upon thee with furious vengeance and anger towards thine Meziere waterpump for his name is Gumpy Pants Greg!
Amen
I do crack myself up sometimes.
Old 06-27-2012, 10:27 PM
fex77k's Avatar
I've used Meziere, Jegs, and CSR. The Meziere is the best built of them. The Jegs is nothing special, but it works fine. The CSR I had lasted about a year before the shaft seal failed, that let coolant in the windings.
Old 06-28-2012, 09:00 AM
Z28Roxy's Avatar
Originally Posted by DVS LT1
I went with their HD pump. I can't say the fan shroud grinding job is noticeable at all unless you have your head down there. Car has never run cooler even before with 160 stat and fan tuning. My temp gauge is in C (not F) but the needle has never gone beyond the halfway point between 0 and 1/4 on the gauge. Usually if there's no stop and go and I'm moving the needle barely moves.
I really wish I had built this motor 12:1 instead of 11:1... how the hell was I ever worried about heat and detonation???? :S
My low compression (9.3:1 or so) 383 generates an assload of heat. I've seen 3/8 on the gauge even with the HD pump. My t-stat is 160 and my fans come on early too.
Quick Reply: Anyone using the Meziere HD EWP?
