Anyone using the Meziere HD EWP?
Old 06-24-2011, 08:43 PM
SS MPSTR's Avatar
Default Anyone using the Meziere HD EWP?
There area few differences between a non-HD and and HD pump - anyone running the HD unit? My circa-1999 EWP has decided to **** the bed, and I'm debating between the two units as replacements.
Old 06-25-2011, 08:05 AM
Village Troll
SS RRR's Avatar
IMO you should just send that one in to have it rebuilt.
Old 06-25-2011, 10:30 AM
SS MPSTR's Avatar
Probably a lot cheaper.
Old 06-25-2011, 10:44 AM
Village Troll
SS RRR's Avatar
I believe they have a $100 flat rate IIRC. I also think the fan shroud would have to be cut into more to make a HD pump fit.
Old 06-25-2011, 12:28 PM
stevo9389's Avatar
yes the HD does protrude more than the non HD pump. you gotta cut the shroud till you almost hit the fan blades.
Old 06-25-2011, 12:32 PM
TAEnvy's Avatar
Whats the difference in flow volume?
Old 06-25-2011, 02:53 PM
stevo9389's Avatar
it is something like 42gpm for regular and 50gpm for HD.
the non HD has been more than enough water pump to handle the hot-lapping and sitting in traffic for me.
Old 06-26-2011, 04:58 AM
gregrob's Avatar
The meziere pumps I've dealt with were all disappointing junk.
The CSR has worked much better and reliably for us. FWIW
Old 06-26-2011, 06:42 AM
Village Troll
SS RRR's Avatar
Therefore art thou Grumpy Pants Greg spoketh to where thou heedeth thine message. If to which thine message is not heedethed, doom and destruction thou shalt strike upon thee with furious vengeance and anger towards thine Meziere waterpump for his name is Gumpy Pants Greg!
Amen
Old 06-26-2011, 09:00 AM
Z28Roxy's Avatar
I'm using the HD pump. I had to go redneck and hack the hell out of my fan shroud - ie about 1/5 of the cover over the fan is gone now.
But after that it fits and works fine
Old 06-26-2011, 09:34 AM
R3DLT1's Avatar
IMO i would stick with the CRS. ive heard to many tragic stories about the Meziere
Old 06-26-2011, 09:44 AM
97LT1's Avatar
meziere hd here. All is good.
Old 06-26-2011, 09:56 AM
R3DLT1's Avatar
With witch ever one u choose to go with theirs is cutting involved.
Meziere- fan shroud
CRS- water pump
Old 06-26-2011, 02:07 PM
BALLSS's Avatar
WOW, my meziere has been on for 12 years now
what exactly makes it "dissappointing junk" for you?
OP
the HD is about 3/8"-1/2" longer than standard and flows more GPH. For my application space is not a problem but my buddy has a 95 F-body and the standard did require some fan shrouud clearing...HD would require more.
Old 06-26-2011, 09:17 PM
gregrob's Avatar
One friend has been through two if them in a short span. Another bought one a while back that was DOA.
Just google and look at all the failures. The local guys who use CSR never have problems. That's what im running as well on the new build.
Old 06-26-2011, 09:20 PM
merim123's Avatar
mez hd here no issues other than cutting shroud
Old 06-26-2011, 09:24 PM
sdotlog's Avatar
Mez HD here.
Old 06-26-2011, 09:42 PM
Matts94Z28's Avatar
Mine has been kickin since 2000
Old 06-26-2011, 10:07 PM
speed_demon24's Avatar
Been rocking my stock pump since like 2005.
Old 06-27-2011, 05:48 AM
Rob
Rob's Avatar
Knock on wood, mine is still going since 2000
Quick Reply: Anyone using the Meziere HD EWP?
