LT1 Hard to start when warm.
Old Jun 27, 2011 | 09:07 PM
93z28ltfun's Avatar
Default LT1 Hard to start when warm.
Hey guys my 93 lt1 doesnt like to start very easy when its hot and after it sits for a hour or longer. it cranks for a few seconds then tries then it starts and is fine after it starts. it cold starts fine. any common problems with this or ideas? thanks
Old Jun 27, 2011 | 09:09 PM
food nd cars's Avatar
my friends C4 L98 likes to do the same thing.. sometimes won't even turn over. Sits it in the shade for awhile and once it cools off it starts back up again. Never figured out what it was tho.
Old Jun 27, 2011 | 09:42 PM
93z28ltfun's Avatar
well it cranks fine. my old 88 ta would kinda do what his is. it would get hot then not crank. turns out it was the starter. swapped it and was good to go.
Old Jun 28, 2011 | 03:30 PM
ebeard's Avatar
I've had the same problem with the starter. I would leave my car running sometimes when i had to run into some place real quick ha.
Edit: People have also had the same symptoms when the ICM gets hot
Old Jun 28, 2011 | 10:16 PM
Gojira94's Avatar
A summer bummer: interior-located electronics that get up to 140* and stop working until they cool off... worth testing.
http://shbox.com/1/fuel_pump_relay.jpg
Old Jun 29, 2011 | 01:18 AM
the_merv's Avatar
Veteran: Air Force
Starter or ICM..I'm leaning toward the Starter..the ICM ***** up in the highend rpm's when it gets hot.
Old Jul 19, 2021 | 05:59 PM
Kitt_Down_Under's Avatar
I know I'm a little late to the party, but for anyone else who (like me) couldn't figure this out for ages, it was my coolant temperature sensor in the front of the water pump.
When it breaks or stops sending signals, the PCM defaults to -40° meaning it starts really well when cold and runs ridiculously rich and won't start when hot.
I replaced the coolant temp sensor in the water pump with a new acdelco one from Amazon and it instantly solved this problem! Starts like a dream now!
Old Aug 28, 2021 | 01:45 PM
Alejandro Guerrero's Avatar
My 94 Corvette did the same thing after putting long tube headers in. The problem was the exhaust was heating up the starter too much that it couldn't function properly. Put some heat shielding around the starter and the problem went away.
Old Aug 29, 2021 | 06:38 PM
phantoms's Avatar
Had a similar issue when I had a leaky injector.
It would restart immediately after turning off but if it sat for around 30 minutes to a few hours it would be hard to start. Sitting overnight it would start fine.
Old Sep 1, 2021 | 09:44 AM
LilJayV10's Avatar
If it's cranking slow the starter is problem getting heat soaked or one of the battery cables is bad. As temp goes up, so does resistance.
