A DYI question from a newbie
With headers and a tubular front crossmember I can change my plugs/wires in about an hour and can swap in a starter in about 10 minutes. Sometimes the race parts actually makes the car easier to work on believe it or not.
BTW: You cannot "drop" the engine. You will need to remove the motor mount bolt on the passenger side and raise that side of the engine a bit to get to the plugs on that side. Will save you a ton of time.
