big power n/a builds?
My build should be between 625 and 650hp at the flywheel...but it wasn't cheap and isn't using many standard off the shelf of popular parts.
Expect to spend more on your valvetrain then most people spend on their shortblock
Let us know how much you have to work with and we can try to piece you together something. There really isn't a set limit to what an NA LT1 can do - just depends on how much you want to spend on it. It's basically a glorified SBC after all...
math said last year it was making around that at the flywheel......et said 640 mph said 660..............but this year its up prob 40-50
At the end of the day though, the best recommendation that I can give you is to ONLY listen to people that HAVE or have BUILT the motor you are looking for (power level). You'll always be disappointed by following generic, regurgitated internet opinions. That is why 80% of LT1 NA builds are what I would consider "under performing", and those builds start becoming the "norm" for the LT1.
I would add that you can't race a calculator either!
The OP needs to set a performance goal. Otherwise this thread doesn't make much sense. One man's idea of big power may not be the same as another's.
